How do I buy a harmonic balancer?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'm building up a motor, and I want everything new. The balancer on this motor is gross looking, and also something like 10" wide! Are they all this big?
So how do I select one? What do you go by? Thanks!
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I don't care how big it is (this one is the 1969 original to the motor!), I just want whatever is best for my build. I'm just not sure what you base the purchase on!
Is the "motor" internally or externally balanced?
In general, you want a bigger diameter damper with more weight on a forged crank. Smaller and lighter on a cast crank.
I always used Fluidampr pieces on my 350 SBCs and had no problems. They cost more, but they work nicely.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: How do I buy a harmonic balancer?
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Are there different sizes, or weights or whatever? I have no idea what to get. I don't want to spend too much, but I want everything done right!
Car: 1989 Iroc-Z
Engine: 350ci SBC
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
That says V6...?
Also, don't I have to know something else, like kevinc said, about being internally or externally balanced?
Car: 1989 Iroc-Z
Engine: 350ci SBC
V6 V8 same balancer. Small Block Chevy Gen I is the application. ..click on application..its says what it fits.
If its a 69 350 then its most likely internally balanced
Transmission: 4L80E/4L80E
V6 and SBC V8.
Unless you have a 383 or 400, you don't need to know whether internal or external balance. All 350-smaller are internal balance.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, good to know! So buy the one linked above?
Also, anything related to this I should get? Or is this all there is to it?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Hmm, I'm going to have to paint quite a bit I think, as everything is new!
I just have to find a place to powdercoat everything
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Be sure and verify timing marks on balancer are correct when you install it. If not purchase the correct timing tab or mark the balancer yourself.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Hmm, the one in the link says for mildly built... does aluminum heads, new cam, and a Stealth Ram still fit under that?
Just want to make sure before I order everything!
