Any problem using new lifters on a used cam?
Old Jul 20, 2001 | 04:43 PM
Jester's Avatar
I know there is a problem going the other way, old lifters on a new cam..does it work the other way? I'm sick to death of my crappy variable duration lifters..and am thinking about swapping them out for normal ones. The cam only has a couple hours of running time on it.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jul 20, 2001 | 04:44 PM
Jester's Avatar
Oh yeah..it's a flat tappet cam not roller.
JSP Motorsports
ICON Motorsports
Old Jul 20, 2001 | 04:56 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
You can put NEW lifters on an old cam as long as the cam is in good shape. What kind of variable duration lifters do you have in it now? I have had some Crane variable duration lifters in my old Dodge Dart for 10 years and never had any problem or noise from them and they made the car a little faster too.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Jul 20, 2001 | 05:12 PM
Jester's Avatar
I have Cranes....do you have any tips for how to get the lash set right? at 3/4 turn, they still tap like hell. At 1 turn, the valves won't close and it won't start. how did you set them?
JSP Motorsports
ICON Motorsports
Old Jul 20, 2001 | 05:58 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Now remember this is on a Dodge 360 engine with shaft mounted roller rocker arms, but I adjusted them while the engine was still on the engine stand and turned the cam till the lifter was on the base circle of the cam, then I tightened down the nut till I had 0 lash on the pushrod and then I went another 1/4 turn. I have never heard the lifters tapping but the engine is pretty loud even with racing mufflers on it. I did prime the lifters by pumping them with a old pushrod in a can of oil before I installed them. As far a Chevys go I have always done it the same way and never had any problems but I have never used these lifters in a Chevy either. I assume you are getting good oil pressure to the lifters? I would drive the car for awhile and see if the tapping goes away and if it don't and it drives you crazy hearing them then you could change them.
T-Tops
3.08 Posi-trac
Crane cam
HyperTech Chip
Old Jul 20, 2001 | 06:29 PM
Jester's Avatar
I just went out and played with them on the engine with it running. I took some from 1/4 turn to about 4 turns past zero lash with no noticable change. I'm giving it one more try, then I'm scrapping them and putting in normal lifters.
JSP Motorsports
ICON Motorsports
Old Jul 20, 2001 | 09:38 PM
Biochem's Avatar
Car: 2002 SOM z28
I think I got the same problem as you bro! Mine are fine when I am under like 160F, but when the engine heats up, they tap like a beoch. Sounds like a bunch of crickets under my valve covers. I do 1/4 turn past zero, tighten the poly lock, then give them another 1/4 turn to tighten the nut so I don't have to re-adjust them in 3 weeks. Stud girdles help...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jul 20, 2001 | 10:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Personally I hate those "variable duration" lifters. I used them in other people's motors at their insistence once or twice when they were new, every time they were dissatisfied.
Since your cam doesn't have many hours on it, you can probably get away with changing out the lifters. The Chevrolet Power Manual has a few comments about it that you might want to read. They even say that old used lifters that still have convexity can be re-used on a new cam... sounds sort of risky to me, but that's what they say. Not that those guys would know anything about motors though.
ICON Motorsports
Old Jul 20, 2001 | 10:35 PM
Jester's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
Gee RB...thanks...NOW ya tell me
JSP Motorsports
ICON Motorsports
Old Jul 20, 2001 | 10:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I thought I did once... nobody listens to me much anyway, I just rant in a vacuum most of the time
ICON Motorsports
Old Jul 20, 2001 | 10:46 PM
Jester's Avatar
LOL well I try to listen to ya Might have just blocked this time out or something.
Will it hurt anything if I leave them in there, tapping badly for awhile? Right now I figure I'll leave them alone. I have them set at 1.2 turn. If they straighten up and stop tapping great..if not I'll replace them....eventually
JSP Motorsports
ICON Motorsports
beastin91rs
Oct 9, 2015 07:38 AM
Reborn756
Sep 4, 2015 03:42 AM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
