What is this? relay? transistor?
Old Mar 23, 2005 | 01:16 PM
TexasB4C's Avatar
Car: 92 Camaro B4C 350
I have a 92 camaro TPI 350 B4C and I found this under the hood mounted in back of the left side (pass) headlight, right where the battery is there were three wires hooked two it, one fell off from all the rust and two were still connected to it.
inside i can see a coil of wire thats why i thought it would be a relay but I didnt think they made them like this anymore?
any help identifying this piece of junk lOL would be great, I just bought the car from someone who raced it locally so hes done a couple of mod sto it and didnt know if this was one of them
thanks
tim
Old Mar 23, 2005 | 04:05 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Circut breaker used for some high amperage things like rear defrost.
That is in rough shape. Was it in the fuse block or duct taped on to the engine or something?
Old Mar 23, 2005 | 04:12 PM
TexasB4C's Avatar
lol there was one bolt bolting it onto the radiator support in back of the pass side headlight, saw it falling apart and took it off to post it to here
Old Mar 31, 2005 | 05:37 AM
TexasB4C's Avatar
anyone else know what this is?
Old Mar 31, 2005 | 12:07 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
It would be earier to identify if you trace where the wires go to.
The only things I've found in that location are relays, fuse holders, and terminal junction blocks.
Old Mar 31, 2005 | 07:24 PM
Vader's Avatar
Yes. What color wires are/were connected to the device?
Old Mar 31, 2005 | 08:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I am unable to view the attachment you have but what you are describing sounds like a power distribution junction block that was on some models. Does it look like the items circled here.
Old Mar 31, 2005 | 09:20 PM
Brazen's Avatar
Car: 91 Z28, t-top, 5.7l ZZ4 rebuild
Engine: 5.7L TPI
Transmission: 700r
Yeah... every V6 I've seen has these including my own 91 RS. Not sure about the B4C though.
Jim
Old Apr 1, 2005 | 12:46 PM
TexasB4C's Avatar
its not the junction block, this is a rectangular "box" made from some metal that has three connectors, one of which rusted off and so ican see inside it and it has a wire coil in the middle of it...
i just looked and saw that there was one black wire coming from the harness in back of the headlight and connecting to it, and one red wire coming from the fan harness (with a couple of other wires) with a big black tee connector with PED stamped on it teeing them off to go towards the battery area...
could this have been a makeshift auxialliary fan relay, it looked like the yellow wire coming from the pass side temp sensor was routed to it too?
where should the factory aux fan relay be?
thanks for the help so far
tim
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
