Stripped oil drain plug...not having a fun time...
Old Jul 22, 2001 | 03:27 PM
Stuart S's Avatar
besides a socket, an open end or closed end wrench, a pipe wrench, or vise grips....how would you go about removing a stripped to hell oil drain plug?
I guess this is why we ALWAYS change our own oil, even if it involves putting the car on ramps in the ice and laying in the freakin snow
Another thought i had was to hammer on a cheap 1/2" socket (should be 9/16, so 1/2 is the next size down)...if i get it on maybe i can break it loose, but I dunno...I realize the socket and plug will be good for the trash, but I dont care...
I also pondered slitting it w/a dremel, but i cant get any leverage with a screwdriver to break it loose even if I did have a slit...
ideas PLEASE?? thanks
not that it matters, but this is an '86 LG4 IROC-Z...
Old Jul 22, 2001 | 03:30 PM
dtpmike's Avatar
Use your teeth. Put it in your molars and twist your head.
How did you strip it? I dont think you are suppose to torque it that much when you put it on in the first place. Do you mean you rounded the bolt off?
Old Jul 22, 2001 | 03:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
6-point socket or box-end wrench... ½" is too small to try to hammer on there; a 14mm might work better if you try to go that way.
ICON Motorsports
Old Jul 22, 2001 | 03:38 PM
Stuart S's Avatar
<font face="Verdana, Arial" size="2">Originally posted by dtpmike:
</font>
I didn't...some dumbass mechanic did...I had it changed this winter last (3k miles ago) because i couldnt get the car up on ramps in the street in the snow and ice...
I could use one of these...LOL
[This message has been edited by Stuart S (edited July 22, 2001).]
Old Jul 22, 2001 | 03:47 PM
Biochem's Avatar
Car: 2002 SOM z28
I would suggest some vise grips. Sorry Rob, I wouldn't advise taking a hammer to the bottom of the pan. It cannot be on there too tightly (ie- not rusted and/or removed in the last 16+yrs...) and look at the bright side, you shouldn't need PT Blaster or Liquid Wrench to get it off!
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jul 22, 2001 | 03:49 PM
Stuart S's Avatar
vise grips just slide off...the corners are really too round to get anything on there...
Old Jul 22, 2001 | 03:53 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Those new type vice-grips that are designed to grab hex head screws and bolts would get it off I bet, I have had good luck using them on rounded off fasteners. They are about $15 or $20 I think. Or if all else fails you could get a small grinder and grind off the head of the screw, that will take off the pressure then you should be able to work the threaded part out with a little pointed chisel and a hammer by tapping on the edge of the threads and spinning it out. Good luck
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Jul 22, 2001 | 04:24 PM
Like a ROC 89's Avatar
If you have a Dremal and a cutoff wheel for it just make a slot like a screw in the head of the bolt and use a large screwdriver to turn it out. If you need more leverage use the vice grips to turn the screwdriver.
sleeper's Avatar
If all else fails have someone weld a nut onto the end of the drain plug.
Old Jul 22, 2001 | 04:36 PM
Biochem's Avatar
Car: 2002 SOM z28
If they just slide off, than you need to tighten them a bit more. At least the vise grips I am talking about have that adjustible handle that you screw in to tighten the amount it closes. I've removed bolts from the block that were just a shaft sticking out with those before... you just need to grip the heck out of it.
Old Jul 22, 2001 | 05:56 PM
b92z28's Avatar
a pipe wrench WILL get it off.
Old Jul 22, 2001 | 08:27 PM
GOLD85's Avatar
get a punch and hammer. put the punch on the head of the bolt and hammer in the direstion u need.
Old Jul 22, 2001 | 08:46 PM
Stuart S's Avatar
Thanks guys...the pipe wrench I had was too big, so I borrowed a mini one from my neighbor...that did the trick...
Thanks for all your help...
gta892000
Aug 11, 2019 11:16 AM
64Chief
Sep 12, 2015 08:05 AM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Amillionoh7
Sep 5, 2015 11:44 PM
