idle's like crap
Old Mar 27, 2005 | 09:10 PM
musicmanz28's Avatar
Car: 09 Silverado, 89 Vette
Engine: 5.3, 5.7
Transmission: 4l65e, zf6
Axle/Gears: 3.73, 3.31
idle's like crap
i have a 92 305 tpi. i just changed number 1 & 3 cylinders, new ac delco sparkplugs. i used brand new bosch plug wires on 1,3,&5 cylinders. i replaced my cap and rotor and everything is in the right place. i moved the rotor a little bit but moved it back to exlactly where it was. i check the plugs for cracks and replaced #3 cylinder. it idles like crap. it feels like its erunning on 7 cylinders. i ran out of time to do the rest but i am gonna take it to a repair shop. i would just like to know asap what could be the problem. thank you fo any input.
Old Mar 28, 2005 | 12:08 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
check your timing.
Old Mar 28, 2005 | 12:28 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Re: idle's like crap
What were you doing with that lose in the first place if you don't have a timing light? Was it left lose and you moved it just doing plug wires?
Old Mar 28, 2005 | 12:29 AM
GravyGut's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: Auto w/ overdrive
Exact same problem here. Changed all plugs, wires, cap, rotor. Will change coil when I get time to mess w/ bolt brackets. Was fine for a day, and then started to idle rough again. Seems like a plug isnt fireing, or its missing. Real annoying at stop lights
Old Mar 28, 2005 | 12:38 AM
Engine: SBC, LS-x
You need to start your own thread cause this one is about something else. Need to bench test your coil and go from there. You can test the pick up coil but usally it's the eletronic module that goes first. No home test for that. Sorry.
Old Mar 28, 2005 | 06:54 AM
Engine: 5.3, 5.7
i was changing the rotor when i moved it
i was changing the rotor when i moved to old one
Old Mar 28, 2005 | 01:17 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
check any vaccum lines by spraying starting fluid on them...if your idle goes up you have a
leak...also checking your sensors may be a good idea
Old Mar 28, 2005 | 10:14 PM
Engine: 5.3, 5.7
fixed
i fixed it, bosh spark plug wiers suck and i will never ever buy them again. one wasn;t making any spark atall!!
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
