wats a good way to get cleance for true duals?
Old Apr 2, 2005 | 02:53 AM
MoroteZ28's Avatar
Car: 1991 pontiac firebird
Engine: 305 V8 flo-pro exhaust
Transmission: automatic 700r4 4speed
Axle/Gears: stock 2.73's :(
my 87 z28 got true dual exhausts with no cats running into two turbo mufflers they sit really low how can i get more clearance i got have 16X8 rims goin in them will that help out over the stock 15's??
Old Apr 2, 2005 | 05:29 PM
sellmanb's Avatar
Car: '86 Berlinetta
If you do it the right way, then your tires will shrink 3 inches when you get the 18 inch tires, so that your speedometer isnt off...
As for more clearance w/ true duals... there's no great way for routing them with as good as stock ground-clearance. The most "ingenious" way I have seen of gaining ground clearance w/ true duals so far is banging the floorboard up and shoving the pipes up there .
I dont know if I would do that though, seeing as the floorboard is part of the unibody, and in a crash, it may fatally effect your crumple zones around the passenger compartment.
If your car is lowered, get stock height springs, that should gain you a couple inches give or take.
Old Apr 2, 2005 | 06:49 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
www.cardomain.com/id/mw66nova
fourth page
onefreakz
May 14, 2018 12:15 PM
beastin91rs
Oct 9, 2015 07:38 AM
Jae992
Aug 27, 2015 09:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
