Exhaust on a TA
Old Apr 3, 2005 | 06:04 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
Transmission: 5 speed
Exhaust on a TA
I just bought my first 3rd gen, and I heard theres no way you can do a true dual exhaust do to the floor boards in the way. So I looked and it seems to be true.
So i have to use a Y- pipe and split it into 2 pipes towards the back of the car....the question is what size exhaust pipes should i go with for the best flow and power?
Old Apr 3, 2005 | 06:10 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You heard wrong. You may have to be creative and have some fabrication skills, but it is very doable. Paired pipes in the channel or oval tubing are the two easiest ways I can think of off hand...
Old Apr 3, 2005 | 06:58 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Several good photos of duals in this post.
https://www.thirdgen.org/techbb2/sho...hlight=%2Bdual
Old Apr 3, 2005 | 08:08 PM
jokers's Avatar
Car: 86firebird/86 trans am
Engine: 2.8ho/305HO 4BB
Transmission: WC T-5/700R4
exhaust
if i'm not mistakin there is a set for your third gen factory. it has 2 cats and a bent pipe for each exhaust manifold. the cats sit where your single cat sits now and the system looks alot like the one you have now. the y pipe is after the cats and goes to a 3inch intermedit than to your cat back muffler. i know i saw it in one of the exhaust books at my local auto parts store.
Old Apr 3, 2005 | 08:16 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
IIRC RPO N10... 1989 up, but that's just dual cats, not dual exhaust...
Old Apr 4, 2005 | 10:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Old Apr 4, 2005 | 12:27 PM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
Didn't someone used to sell that dual pipe in the channel set-up? And home-made oval tubing isn't exactly easy to do.
Old Apr 4, 2005 | 02:48 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
wow thanks for the insight, theres no engine in it currently, im rebuilding one for it, so there is no exhaust either, so i have to put one 2gether.
Old Apr 4, 2005 | 06:11 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
i really liked that one set up where the two pipes go to the driver side i would think it was, and come out right before the back tire. looks real cool, prolly sounds nice as well
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
