Car Won't Turn Over
Old Apr 6, 2005 | 05:09 PM
90RScamaroV6's Avatar
Car: 90rs camaro
Engine: V6
Transmission: automatic
Car Won't Turn Over
I have a 1990 RS V6 camaro. I installed a new ignition and new VAS key. The problem now is that it only starts when I turn the switch on and ground the starter. When I turn the switch I hear the fuel pump prime for a few second but there is no sound from the starter. I took out the started and had it check out and it is OK. The only click I hear is coming from the drivers side kickpad. I open it and saw a relay there. Would that cause the car not to turn over. Any suggestion are welcomed..
Old Apr 6, 2005 | 06:14 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Well, it could be a few things really, Check your neutral position sensor, sometimes mine does that and i have to grab the connector and wiggle it a little and then it starts, or it could be bad. Could be in the ignition. When they checked the starter they also checked the solenoid right?
Old Apr 7, 2005 | 03:58 PM
Car: 90rs camaro
Engine: V6
Yes the solenoid was checked and Ok. I will check the P/N switches and see what happens. Thanks
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
