How can we put a car on a trailer?
Old Jul 27, 2001 | 11:28 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I might be purchasing a project car and was wondering how could I get it onto the trailer. It doesn't run. We could always push it up onto the trailer but these cars are freaking heavy. Is there any place I could use a winch to help or anything like that?
Old Jul 27, 2001 | 11:47 PM
rezinn's Avatar
Do you live near a hill? Use gravity! Im sure you could attach a winch to the frame to pull it up.
Old Jul 28, 2001 | 12:05 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
A winch would be the best way, I've used come-alongs before, but what a workout and a PIA.
Word of caution form the "been there, done that" squad....if you plan on rolling the car down a hill onto the trailor, make sure the brakes work first. Don't ask me why, just trust me
Old Jul 28, 2001 | 03:46 AM
Jza's Avatar
Jza
If you use anything with a hook, don't stick 'em in the holes in the subframe. Don't ask how I know that.
When my fuel pump went south, I had to use a hill to get it on a trailer.
To add to 8Mike9's warning about the brakes, also make sure that the vehicle that the trailer is attached to has IT's brakes on.
Old Jul 28, 2001 | 08:27 AM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Okay. I probably could use a winch, but where could I attach it to without messing anything up? And the closest hill around this car is like 50 miles away. The brakes do work too. You can get the full scoop on the TBI board.
Old Jul 28, 2001 | 09:39 AM
Stuart Moss's Avatar
I'd like to know the answer to that question too.
On my '91 Z28, there are two pieces of metal (~1/8" thick) that extend down with an oblong hole. They are located at the outer sides immediately in front of the sway bar, flush with the inner side of the wheel well. It looks like these were intended to secure the vehicle when being transported, but wonder if they can also be used to pull it. I don't think it'd be good to tow it there though.
Does anyone know where the tow points are on a third-generation F-body?
Old Jul 28, 2001 | 10:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Best place is around the K-member, under the engine. You could hang the car off a cliff by that part, it's the closest thing to a frame these cars have. If you do it that way, be careful of the steering and exhaust. Next best place to winch it from would be the control arms.
Make sure you've got it tied securely down... I was involved in a situation once where a car was backed onto a trailer, and tied with rope; the tow car had to stand on the brakes; when that happened, the rope broke, and the trailered car ended up on the trunk lid of the tow car, with the bumper on the trunk lid and the wheels dangling. Just a little less restraint from the rope before it broke and it might have rolled over the trunk and crushed the occupants of the other car.
ICON Motorsports
Old Jul 28, 2001 | 10:29 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Just get a 6-pack of beer and about 3 fat friends to push for the prize!
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 28, 2001 | 09:27 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I was thinking the safest way would be to push it. Could anybody post of picture of where to attach a winch? K-member?
Old Jul 28, 2001 | 10:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You can pull under crossmember under the engine, just be careful and keep an eye on the cable, it may want to come in contact with the plastic nose piece, you'll end up slicing it through if you're not careful...uh, and don't ask me how I know that either...
Old Jul 30, 2001 | 09:11 AM
ATOMonkey's Avatar
I'd go with friends and beer approach. Not only will it get done, but you'll have a good time doing it. It's also the most economical as far as I can tell. Good places to tie down are chains over the axle, and then use nylon straps with ratchets to pull the car down. Load the car to the front of the trailer so it rolls to put tension on the chains. Plus you want enough tong weight on the trailer that it doesn't bounce and get the rear of the truck light. Then pull down really hard on the straps in the front. It should be tight enough that the suspension actually starts to compress. That way you know it won't bounce off the trailer.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 A&A snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Jul 30, 2001 | 09:23 AM
Chronos_Titan's Avatar
Don't be a sissy just get about 5 or 6 friends together and make sure none of the brakes are stuck. Even little wimpy guys can move one of these cars if you get enough and you do not need a whole lot. Just be sure the car is held down really well on the trailer. NEVER USE ROPE!! The only rope I would trust would be about the thickness of your wrist. Go invest in some good nylon strapping and chain pull that baby down tight. After you drive about 100ft you will probably need to check everything again.
84 Z28 383
Stripped w/Cage back halved w/ladder bars and coil overs and 9 inch
700R-4 3.73
Old Jul 30, 2001 | 09:50 AM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Stuart Moss:
On my '91 Z28, there are two pieces of metal (~1/8" thick) that extend down with an oblong hole. They are located at the outer sides immediately in front of the sway bar, flush with the inner side of the wheel well. It looks like these were intended to secure the vehicle when being transported</font>
Those are exactly that. You can use those points to pull also but the direction of pull has to be in a straight line with them or they will bend. Alternativly you can use just about any strong part of the undercarriage. A-arms have always been a favorite for me (right next to the mounting bolt at the subframe).
hokis
Aug 9, 2015 03:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
3rdgenparts
Aug 6, 2015 09:03 AM
