Cam duration= Power
Old Jul 30, 2001 | 12:57 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Cam duration= Power
I have been thinking about a cam change in my 305. I have a LT-4 cam with the 204/210 duration. What would be the outcome if I went to a cam with a 218/224 duration with the same lift.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jul 30, 2001 | 01:10 PM
RW91B4C's Avatar
Duration affects the rpm band of an engine - at what rpm it will make peak tq and peak hp.
That would be a big cam for a 305 - it should pull to 6000. If its the comp extreme then get it ground on a 112 or 114 LS - it would help out with idle, low-end, and mileage
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Jul 30, 2001 | 02:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
In general, a cam with more duration will move the power band up to a higher RPM. In a TBI 305, with that cam you would need a higher stall converter to keep from losing alot of punch off the line. If the lobe separation is the standard 110° for that cam, it will also make the idle quality very poor, which will require a new chip. You can improve the idle by having them custom grind it on 112° or even 114° centers, but that will reduce bottom end torque even more.
Also, that Xtreme 262 is a flat tappet cam. You should use a roller since your existing cam is a roller.
I'd suggest the Comp "302" roller grind... 264HR-12
This one should not require a new chip. Be aware though, it's on the very edge of working for sure with Vortec heads; with gross valve lift above .480", there is a possibility that the retainers will hit the valve guides.
ICON Motorsports
Old Jul 30, 2001 | 03:10 PM
Well I was looking at the General motors cam with the 112 lsa. I do have the 2500 stall converter and custom chip for the LT-4 now but I was pattering this motor off of the car craft 305 325hp buildup. The problem is the cam they used has less lift and more duration than the LT-4. I also have the timing chain cover off right now would be a good time.
Brian
1989 Camaro RS
Old Jul 30, 2001 | 10:05 PM
btt
1989 Camaro RS
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
