Turning air cleaner lid upside down ???
Old Jul 30, 2001 | 07:25 PM
NHcamaro's Avatar
I was going out for breakfast with some of my friends and one of my friends was saying how hes cuz told him to turn his air cleaner lid upside down and it'll get more air. So here tried it on my truck.. seemed nice.. But I was wondering if I did that on mine on my LO3 if it would help it or hurt it.. Any1 every hear of doing this ?
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
AOL: RyanNH84
Old Jul 30, 2001 | 07:32 PM
R.O.B.'s Avatar
By turning the lid upsidedown, just make sure it still seals completely around your filter. You can see a little gain because this now allows more air to enter. Intead of the air needed to go through the small intake ear off the main peace, it is now similer to an open element air cleaner. In my opinion, this can have a down side because of hot air, plus, I think the gains may be more exagurated, because now it "sounds" like it works better.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Old Jul 30, 2001 | 07:38 PM
NHcamaro's Avatar
thats what I was thinking...
Old Jul 30, 2001 | 07:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Most of the time, it hurts more than it helps...
Look at the lid. Notice that the place where the wingnut goes is higher than the ring where it seals to the filter. Now think how much closer to the air horn it's going to be when you turn it upside down.
It will probably make your car go slower. The extra noise usually recalibrates your butt dyno by increasing the blood pressure in your male member. The only time it helps is if you have a nest of mice living in your air cleaner's snorkel or something like that.
ICON Motorsports
Old Jul 30, 2001 | 11:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I did it and used a taller K&N air filter at the same time. That kept the lid away from the air horn of the TB.
One guy on here did a chassis dyno pull fore & aft using the same paper filter. He said it picked up 6hp on his L03 after he did it. It's not exactly SOTP improvement, but 6hp is 6hp. Can't knock that.
AJ
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
