Starter Brace/ Bracket
Old Apr 12, 2005 | 08:06 AM
little8camarors's Avatar
Car: 92 Camaro RS TTop,91 Camaro RS vert
Engine: 305 TBI V8
My starter doesn't always crank but you can hear the soleniod when the key is turned. After turning the key a few times rapidly it starts. The starter was replaced last year hoping to fix the problem. I have noticed that when it does this if pressure is put on the end of the starter (not the nose) it starts right up. In the Chilton's manual (page 3-7) I can see a brace/ bracket on that part or the starter that I dont have nor do I see were it bolts to on the block. Anyone got a pic of were it bolts to? Do you guys think this may be the problem? I have pulling my hair out sence I bought the car and want it fixed.
Old Apr 12, 2005 | 09:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like the 2 long screws holding the start together, are loose. Or, if that doesn't fix it, the bushings are worn, and the armature is touching the pole pieces; in which case you just need a new starter.
The brace is a good idea though. It bolts from a bolt hole in the block right below the head deck, to one of the long screws in the starter.
mcbitchman
Sep 30, 2015 01:00 PM
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
Cleotiz
Sep 16, 2015 08:02 AM
Formula_88AE
Sep 3, 2015 01:47 PM
