Align Bore/Honeing The Main Caps
Old Apr 14, 2005 | 02:37 PM
JesasaurusRex's Avatar
Bout to take my block tot he machine shop cuz i want 4 bolt splayed caps in my 2 bolt 400 block. Gonna get teh thing align bored and i was curious about something. Yes i did a search already couldnt find anything. Would that not require special main bearings seeing how they are taking material away from the cap side and block side of the main. However i cant seem to find any store (jegs/summit/sdpc) that sells them. Whats the deal with align boreing and bearings fellas. Thanks.
Old Apr 14, 2005 | 02:58 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The way I understand it, they take material off of the cap and block faces. This creates a kind of football-shaped main journal hole. They then bore the holes round again to the original diameter. You just need to purchase bearings that provide the correct amount of bearing/crank clearance.
Also, the center lines of the crank and cam are now closer together. I think you need to buy a special timing chain set with a shorter chain that compensates for the material removed from the cap/block face.
Old Apr 14, 2005 | 02:59 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
The way I understand it, they take material off of the cap and block faces. This creates a kind of football-shaped main journal hole. They then bore the holes round again to the original diameter. You just need to purchase bearings that provide the correct amount of bearing/journal clearance.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That depends how much they actually take off. There could be core-shifted factory blocks out there with less cam to crank centerline distance than you'd have after milling the caps.
Old Apr 14, 2005 | 04:01 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Be aware also that you might need a special main seal depending on how much is taken off. Your machinist should know the part number.
Old Apr 14, 2005 | 08:19 PM
Anybody know who sells those bearings?
Old Apr 14, 2005 | 09:44 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The way my machinest told me was they cut the main cap bolt on then realign. Same bearings
Old Apr 14, 2005 | 10:42 PM
lol so who had this actually done before?
Old Apr 14, 2005 | 11:00 PM
wesilva's Avatar
Transmission: 200R4
I've had it done to 4 different 400's. Your not going to need special "bearings" but possibly a special main "seal". The Felpro part number is 2909. It goes for $19.99 through Jegs with their part number being 375-2909. The reason I say "possibly" is if a minimal amount of material is removed, a standard seal will work. Again, your machinist is most qualified to make that call.
Old Apr 14, 2005 | 11:12 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
My block was align honed... no need for special parts or anything. Everything looks great.
Old Apr 15, 2005 | 02:03 AM
k thx fellas appreciate it
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
TBRays98
Sep 6, 2015 05:05 PM
