305 crank n' rods w/ a 400
Old Apr 15, 2005 | 01:02 PM
1986camarojoe's Avatar
Car: Z28
Engine: 310
Is this possible? If so, what does it make??
Old Apr 15, 2005 | 01:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you managed to balance it, you'd have what's popularly known as a 377.
Old Apr 15, 2005 | 01:35 PM
Car: Z28
Engine: 310
Then, if I get it bored its a 383?
Old Apr 15, 2005 | 01:46 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
A 383 is a bored and stroked 350. A 350 block with a 400 crank and an overbore.
Old Apr 15, 2005 | 02:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
400 block std bore (4.125") w/ 305-350 stroke crank (3.48") = 372
same thing, .030" over = 377
You need spacer bearings, or bearing spacers
Little point in spending extra money to downgrade a motor
Old Apr 15, 2005 | 04:07 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Wht use would a 377 have? It would hvae less stroke, so it could rev higher, right (or some such nonsense) ? Doesn't torque come from stroke? Sounds like it would be a gelding after it got de-stroked.
Old Apr 16, 2005 | 01:11 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
The destroked 377's are hi reving motors. They make great top end power. Most i have seen were spinning to the 8K range.
Old Apr 16, 2005 | 01:18 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
torque comes from cylinder pressure, and the easiest way to influance torque is with cubic inches. you normally dont see more than 60-70 pound feet of torque per liter(unless its a supercharged application). 70 pound feet of torque per liter is an increditable amount of torque. my l98 tpi motor make 372 pound feet of torque at the wheels at 2250rpm. that is almost a rediculous(it is rediclous because you dont need that much torque at that low of an rpm) amount of torque for a motor as small as mine to make with stock heads and bore/stroke/comp. i ask someone to just show me how a car is a faster car through the 1/4 mile by adding torque, without adding weight. add 50lbs of torque to a car and it will accelerate just as quickly(assuming the car had sufficent torque to move the car in the first place). you dont need more torque, you just need a big enough converter. id gladly trade 50lbs of tq for 50hp, then my car would not break rearends with the consistancy it has for the past 2 years, and be faster too.
Hotrodboba400
Dec 10, 2019 07:07 PM
anesthes
Sep 18, 2015 12:34 PM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
