Removing park lock cable from steering column?
Old Apr 17, 2005 | 01:44 PM
RestoRoc89's Avatar
Car: 1987 Iroc-Z/1993 Z28/2011 Corvette
Engine: 350 CI TPI/355 CI LT1
Transmission: 700R4/D&D Performance T56
Axle/Gears: 3.27 9-bolt/3.73 10-Bolt
Hello all,
I'm in the process of removing my steering column and have it laying on the floor of the car...my only problem is, I can't figure out how to remove the park lock cable from the steering column. This is the cable that runs from the column to the shifter. I've seen some diagrams posted on different forums, and instructions saying to turn the ignition lock cylinder to the 'RUN' position and use a screwdriver in the appropriate slot to disengage the cable. Where is this mysterious slot?!? I've been looking and prodding at things, and I'm stumped.
Any help would be greatly appreciated!
Thanks,
RestoRoc89
Old Apr 18, 2005 | 04:13 PM
RestoRoc89's Avatar
Anyone?
Old Apr 18, 2005 | 10:17 PM
RestoRoc89's Avatar
Nevermind, I got it...there's a little slot with a plastic tab inside...sure enough...stick in a screw driver and out if comes...You have to appreciate how everything always takes five hours longer than it should the first time.
Old Dec 25, 2022 | 01:33 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Removing park lock cable from steering column?
I had a hard time figuring out what to press to release this cable from the ignition switch and none of the other posts showed photos. So here's one I took that might help the next person trying to get this out of the ignition switch. Some posts said the ignition switch had to be in Run. I don't remember that mattering on mine, but it is something to be aware of. I kind of slid the pocket screwdriver down between the black plastic tab and the metal tab, so it forces the plastic tab down then rock the screwdriver to push the cable out.
Here's a couple of pics of the switch and the cable separated
Old Dec 25, 2022 | 03:30 PM
RestoRoc89's Avatar
Great addition, Lurbie! My ‘89 Iroc succumbed to rust problems years ago, but I actually picked up a mint, low mileage ‘87 this past fall and have just started actively participating in the forums again.
Old Dec 25, 2022 | 07:02 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
THANK YOU!!! I've been searching for just such instruction.
Old Dec 27, 2022 | 06:35 PM
dstss's Avatar
Car: 1992 TA Convertible
Engine: 5.0 TPI
Transmission: THM 700
Swapping my auto for a 6 speed stick. I was trying to figure out how to lose that cable. Good info, thanks for posting.
Old Dec 27, 2022 | 07:17 PM
Lurbie's Avatar
Car: 89 Camaro
Glad it helped. I'm doing the same swap, took the 700r4 out, putting in a T56 Magnum from Hawks Motorsports.
Old Apr 8, 2023 | 08:19 PM
smokesm's Avatar
Park lock cable part number
I have been looking for the GM part number for the park lock cable. Does anyone have the part number? It's for a 1985 Firebird.
rich5
Aftermarket Product Review
Apr 12, 2016 10:34 AM
lukerene
Sep 26, 2004 11:26 AM
aaron7
Jul 19, 2004 06:23 PM
speedfreaker
Feb 4, 2002 05:18 PM
