Motor swap HELP PLEASE!!!
Old Apr 18, 2005 | 11:02 AM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
I have a 91 Camaro RS w/ a 305 TBI. I have a '75 350 4-bolt main block I am building w/ some Vortec heads & numerous other things. My question is that I originally have a passenger side oil dipstick and the 350 has a driver side one. I need a new oil pan anyway so I am wanting to know what year (and out of what) oil pan I need to put on it so that I can put a new dipstick in it.
Any help would be greatly appreciated!
Old Apr 18, 2005 | 11:48 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Try Summit, part# SUM-G3500X . Is that what you mean?
Old Apr 18, 2005 | 12:15 PM
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
That is what I am talking about as long as it will clear the crossmember in a Camaro. It looked like it would hit...but it is just a picture.
Old Apr 19, 2005 | 04:54 AM
IROC-Turbo's Avatar
From what i seen running that part number the dipstick is still on the drivers side.And the way it sounds you want to keep it on the pass side like factory.The driv side dipstick wont work with factory manifolds unless you want to squeeze it up against the block.Its does work like that but it makes it hard to get back in some times.Your other option would be getting headers as i take it the dipstick with clear the headers.I dont know of a custom pan that will plug the driv side dipstick hole and has a provision welded in the pass side for a the dipstick.
Old Apr 19, 2005 | 07:09 AM
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
I have headers for it. I am not really looking for a custom pan, but just a pan with the provision for a driver side dipstick (to match my block) that will fit in the Camaro chassis.
Old Apr 19, 2005 | 08:04 AM
Confuzed1's Avatar
Car: 83Z28 HO
It worked in my Camaro with TES headers and Y-pipe.
Old Apr 19, 2005 | 08:21 AM
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
Confuzed1? You said that that Summitt oil pan is the one you have in your car, and is yours driver side dipstick. If so what dipstick did you use?
Old Apr 19, 2005 | 10:07 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
My 355 is a 74 block, I got a new generic chrome dip stick and new generic chrome oil pan for a block with the driver's side dip stick off ebay for like $30.00 and it all fit.
The oil pan plug washer was crappy and I replaced it with a teflon washer I made frome some scrap at work. No leaks now.
There were no clearence issues and the oil pan was just a regular sbc oil pan for any chassis.
I did use headers too so I had no issues with manifold clearence.
EDIT:
Manifold clearence to dip stick that is.
Old Apr 19, 2005 | 10:08 AM
Confuzed1's Avatar
Car: 83Z28 HO
Not sure of the brand - it's just a cheapie chrome one, pretty much like the one Mr. Gasket sells. And yeah, it's the driver's side dipstick. And you can't change what side the dipstick is on, the dipstick hole is in the block, not the pan.
The Summit pan I bought is no longer on the engine. I've since upgraded to a GMPP pan w/windage tray. If you were local, I'd sell ya mine for 20 bucks - it was only on the car for 6 months and looks pretty much new! Now it's just sitting in a box....
Old Apr 19, 2005 | 11:44 AM
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
I know I can't change the dipstick side...not trying to. But I do appreciate all of ya'lls help. I will order one of those Summitt oil pans and use it. I was just wanting to know about clearance. Thanx.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
