type of heads
Old Apr 18, 2005 | 09:07 PM
slidNsideways88's Avatar
Car: Firebird
Engine: V8 305
Transmission: 5 speed
type of heads
once again im back looking for advice im building a 383 engine looking for big torque with around 9.5 compression ratio just wonder what type of heads would you guys consider and to go with cast or aluminum
thanks for your thoughts
Old Apr 18, 2005 | 09:52 PM
flieswithjunk's Avatar
Car: 90 firebird
Engine: 4BBL L98 350
Transmission: WC T5
I built a 383 with vortec heads with great hp and a ton of torque
I used a comp cams 274XE cam and ported the heads. the vortec heads are weak on the exhaust side so port the crud out of the exhaust side but the intake only needs the throat opened up,bowls blended and the short side turn smoothed
Old Apr 18, 2005 | 10:26 PM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
I have to agree with the dude that flies with junk . Vortec are the way to go. Personally I think that alluminum heads aren't worth the hassle, especially since just about every 3rd gen Camaro likes to run hotter than it should.
Old Apr 19, 2005 | 11:40 AM
Car: Firebird
Engine: V8 305
thanks for the suggestions
colton_carlson
Mar 8, 2019 12:21 PM
z28guy134
Sep 1, 2015 11:50 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
bdads
Aug 24, 2015 06:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
