Speedometer
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Speedometer
Hey, guess whos back for more questions!
Yes this swap is quite the little headache but still.
Anyways, question for today is this.
If I have a TH350 from my 79 that had 3.73 rear gears, and its being put in my 1984 with 3.42 gears, is the speedo gonna be way off?
And can I self calibrate it or must I take it to a shop?
Thanks for replies
Thanks for replies
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need to mess with the speedometer head, just change the speedometer gears in the tail of the transmission.
Engine: 355 TPI
What do I look for in speedometer gears? To match my rear gears? I'm not quite sure what I'm looking for is all.
Engine: 355 TPI
Currently running 215/65/R15 in back. Which I'd like to add came from the 79 (since I busted my rims that one awful night)
Engine: 383 Carb
Transmission: 4L60
An 8 tooth drive gear (6261783) and 22 tooth driven gear (2987922) should get you pretty close.
Engine: 355 TPI
Ok, I'll google those numbers and try to find it. You know of any good sites that explain how the speedo thing works out because I don't quite understand it.
Btw are those GM part numbers next to the dif gears?
Elephantismo
Feb 13, 2019 12:51 AM
