Fuel Tank Capacity
Old Aug 5, 2001 | 10:13 PM
Patrick007's Avatar
Fuel Tank Capacity
What is the fuel tank capacity for an 89 Camaro RS? Just trying to figure out when i'm ACTUALLY getting near empty. Thnx guys
PDJ
Old Aug 5, 2001 | 10:15 PM
JETHROIROC's Avatar
It's 15.XXX gallons, I think.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
kingtaling's Avatar
I have the same car... I think its 15 Gallons but im not COMPLETELLY sure. I've had it fill up to like 13.5 gallons before with the needle barelly above the little red line.
Old Aug 5, 2001 | 10:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The rating is 15.5 gallons.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 5, 2001 | 10:53 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I ran mine dry (on purpous(sp?))and it took 16.35 gallons to refill.
Old Aug 5, 2001 | 10:57 PM
Engine: 383
Old Aug 5, 2001 | 11:01 PM
Patrick007's Avatar
Alright then.. so i'm not as empty as i think i am.... Thnx guys
PDJ
Old Aug 5, 2001 | 11:12 PM
un4givin89's Avatar
thought it was bigger than that, its small then. No wonder I keep running out.
Old Aug 6, 2001 | 12:35 AM
One Eyed Jack's Avatar
The tank is shaped very oddly. I can run 100 miles before the guage even moves off of FULL. Then it gets faster and faster towards the end.
Old Aug 6, 2001 | 01:10 PM
tacoboy's Avatar
My owners manual for my 84' said 17.something...wonder why that is because it sure seems more like 15.something
Old Aug 7, 2001 | 11:14 AM
Patrick007's Avatar
While on the topic of fuel... whats the average MPG that you guys are geting? Just for a comparison to see if i'm too rich.. cuz it sure seems like it.. lol. But then again it aint meant to go cross country on a tank of fuel either...
PDJ
Old Aug 7, 2001 | 11:49 AM
Xenodrgn's Avatar
Yes, the tank is shaped -very- oddly...
As far as MPG... I'm getting about 14 on my little 6, with no mods... lol. But my ignition is -completely and utterly shot-, so I have an excuse... (you guys should see my pickup coil... it's a joke, when the chick at Strauss handed me the new one, I was so surprized to see what it's -really- supposed to look like.. )
If you really wanna find out, disconnect the fuel lines and run the tank dry, (try and let it drip out, or run out... don't run the pump dry, it causes premature wear) then see how much it takes to top off, thats the best bet...
From what I've heard previously from people who have run their tank dry is that it's about 16-16.5 gallons... the reserve as far as the needle goes is about 3 gallons...
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Aug 7, 2001 | 07:37 PM
Guest
Guest
Posts: n/a
I cant get more outa my tank than 14.3 gallons.
The rated capacity is 15.5 gallons.
Old Aug 7, 2001 | 08:22 PM
un4givin89's Avatar
I get $hit for gas milage. My lil 305 loves to suck it all down.
Old Aug 7, 2001 | 09:09 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Im in the same ballpark as you guys. From where ive ran out a little above Empty where I now tend to fill it up at I can squeze 11.9 gallons into it "I just filled up today" My owners manual says its 16 gallons but Ive yet to get that in it.
Economy wise my over cammed lg4 was getting 22mpg city with the edelbrock now that I got a holley sitting on top Ill have to wait a week to see.
SSC
Old Aug 7, 2001 | 09:21 PM
RyanSS's Avatar
I thought something was wrong with my car for awhile, it would die in traffic when I would brake hard, turns out I was so low on gas all those times, that it uncovered the fuel pickup and died from lack of fuel.
Do you guys' gas gauges move when braking and accelerating? Mine does, I've had it move almost 3/4.
And yeah I HATE the way it stays on F for about a 100 mi. then goes down sooo fast, makes it hard to discern how much gas you actually have.
Back to the ?, I have put almost 16 gal. in mine.
I have no idea on gas mileage, about 21 or so highway, upper teens in the city.
89 RS 350 TBI auto Hooker SC/LT headers Open element 3in K&N CVT protorque mini-starter
Daily driver 91 RS auto LO3 63k
New project- 89 Formula 350 WS6
383 or 400 to come!
Old Aug 7, 2001 | 09:40 PM
Jza's Avatar
Jza
It's gonna vary for some cars, since at some point a vacuum or pressure situation will change the volume of the tank (maybe a vent that got stuck for a bit, or expansion on a hot day).
I'm interested in those owner's manual specs though. My owner's manual says 15.5..
Before I installed my new tank, I tapped out the walls some so it could hold a bit more gas.
Old Aug 7, 2001 | 11:26 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Jza:
</font>
Yea Im curious also, I know that my camaro fills up closer to 15 gallons than my firebirds 11.9. I know theres a big weight difference between the 2 fbodys fb weighs alot more and I wonder if the fb's tank is supposedly larger page 7-4 of the owners manual says 16 gallons "82 Fb".
But this brings me to this question since I dont have the owners manual for the camaro, Is the capacity stamped anywhere like the door sticker? If so I'll stop by the storage place and take a peek for comparison. Or if anyones got thier owners manual for thier 12/85, "?86?" camaro post the capacity.
SSC
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
