What is this thing? (oval hole in pass side floorpan)
Old Aug 12, 2001 | 03:19 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
After just paying almost $200 to have a giant section of my driver's side floor replaced, I peeled off some sticky insulation that covered a weird oval hole on the pass side. It appears like it's supposed to be there, but there is some rust (rot) on one edge, and a shiny but thin piece that covers the hole but certainly doesn't make anything watertight. I should post a pic, but does anyone know offhand about this hole? What options do I have to eliminate the rust in this area?
Old Aug 12, 2001 | 04:53 AM
LarsZ28's Avatar
I had a similar situation. Mine was on the drivers side though. I took my carpet out for other reasons, and I noticed an oval shaped hole in the tranmission tunnel in between the rear seats. I figure that it was the torque arm rubbing on the tunnel and finally tore the floorpan, or someone cut it to make clearance.
I have a pic, but its not on the net..
Old Aug 12, 2001 | 06:52 AM
El Guapo's Avatar
You reckon thats a drain hole that is just missing its cover? I know in certain places there are drain holes. You know, so in case you try to turn your car into a submarine or something.
Just a thought.
Clayton
Old Aug 12, 2001 | 08:22 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Yes, those are floor pan drain plugs. Why they are there I don't know. They are impossible to get out and tough to put back in. More of a holdover from older car's I think.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Aug 12, 2001 | 08:58 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
Yes, those are floor pan drain plugs. Why they are there I don't know. They are impossible to get out and tough to put back in. More of a holdover from older car's I think. </font>
You are correct about the holes, but they are not really there as drain holes.
If you get a chance to walk through an assembly plant, watch what happens with all those holes. Some are used for gauging the positioning of the pan when the subframes are spot welded in place. Some are used as access holes (to stick a hand or tool through to start a bolt, etc.) And some are used as handling or grappling points. The Fischer Body design boys get to figure out how the car gets assembled, then select the best (most useful) place to punch these holes for multiple purposes. When it's all done, a cover get glued/sealed in place and we get to wonder about them for eternity.
Just in case you wanted to know.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Aug 12, 2001 | 10:00 AM
LarsZ28's Avatar
Oh well, that hole of mine was caused by the torque arm Darn 9" moved the torque arm out too far, and rubbed its way into the cabin..
Old Aug 12, 2001 | 08:54 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Thanks for all the replies! I guess I'll just cover this back up, I'll probably sand it down top and bottom and apply some por15 first.
Old Aug 12, 2001 | 10:23 PM
camaroguy99's Avatar
Vader, is there anything you don't know?
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Bob88GTA
Aug 18, 2015 03:31 PM
wruiz
Aug 11, 2015 02:59 PM
Elliswon
Aug 10, 2015 12:33 PM
3rdgenparts
Aug 5, 2015 11:57 PM
