XE268 Cam in stock 305 = fine???
Old Aug 13, 2001 | 07:13 AM
LarsZ28's Avatar
I want to put a XE268 cam into my LG4 motor. I know I have to change the valve springs to suit the cam, but apart from that will it work fine in my otherwise stock LG4 motor?
I am not trying to get the most power out of this motor now, I just want to put it in while my water pump and radiator are out of the car, until I get the vortecs. (have a T-5 so dont need a hi stall )
Thanks!
Old Aug 13, 2001 | 10:56 AM
RW91B4C's Avatar
If you're going to get some vortecs, and a exhaust system amd maybe an intake for it, it should work good.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Aug 13, 2001 | 08:56 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Go get the latest CHP magazine. They are putting a new cam in a LG4 and they went pretty mild. They made a good point that the 305 lacks in low RPM torque as it is. Going with a too aggressive cam will just add to that problem. They went roller, but the article posts the specs of the cam that may help you.
AJ
Old Aug 13, 2001 | 09:58 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have that cam in my 350. To make it work right you'll definitely need a really free flowing exhaust, torque converter and gears. I don't remember the compression of a LG4 but you'll probably need more. If you do use your stock heads for a while before the vortecs get a thinner head gasket. I don't think that it will be to radical if you set it up right.
Remember the torque converter. That is the last thing that I did and it should have been the first thing I did when I did the vortec head and XE268 swap. The stock one just didn't like the bigger cam.
Old Aug 13, 2001 | 10:05 PM
iroc5speed's Avatar
94-6spd, he does not need a new torque converter, as he has stated that he has a manual transmission. with an auto he would with a more powerful engine, but he has a t-5 tranny.
camaro71633
Sep 1, 2015 10:24 AM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
