One of the most annoying problems with thirdgens
Old May 5, 2005 | 01:10 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
IS THE WAY THE $#^ING WINDSHIELD WIPERS GO OVER THE TRIM AND HIT THE PAINT!!!!
It's caused my paint to scratch then flake TWICE now. Is there *any* way to fix this? I rarely use wipers and often coat RainX on, but WTF GENERAL MOTORS?!
Old May 5, 2005 | 01:32 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
my 83 does not go over the paint. Maybe someone put too long of wiper blades on it.
Old May 5, 2005 | 02:40 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
my 86 doesnt hit either. you could probably replace with shorter wiper arms or blades.
Old May 5, 2005 | 04:19 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
That not a 3rd gen specific problem that just your problem. Somebody replaced stuff with the wrong parts.
Old May 5, 2005 | 05:18 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Mine did the same thing until I adjusted them properly. Works fine now.
Old May 5, 2005 | 05:32 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
No problem with my '87's wipers. (edit:don't remember having any problems with the '88 either)
Make sure nothing is bent/damaged/worn out, and you have the right length blades. Also make sure they are all the way down when turned off.
Old May 5, 2005 | 10:21 PM
AsphaltAssalter's Avatar
Car: 92 Camaro
Get you facts correct before you go blaming a whole generation of cars for a problem only you have!!! I've owned 3 3rd. gens and none have that problem.
Old May 5, 2005 | 10:31 PM
92'Sleeper's Avatar
Car: 92' B4C Camaro
Transmission: G-Force T5
The 84 I had and the 92 I have now never had this problem.
Old May 5, 2005 | 11:19 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Mine does this. You need to pull the clip outward. Raise the arm up and move it over a couple teeth. That will fix it.
Old May 6, 2005 | 12:15 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
That will help but in my case it didn't do enough. I had to remove the cowl screen and adjust the linkage. But it was like 10 minutes of playing with it and it works fine now. It is unlikely that you have the wrong parts, probably just need to adjust it.
Old May 6, 2005 | 01:25 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Wow adjustable? My wipers are non adjustable, blind spline left side and the passnger have the off set dojamhicky making them impossible to put on more then one way.
Infested
May 22, 2018 11:56 PM
TheJoeY88
Dec 31, 2016 07:30 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
sreZ28
Aug 14, 2015 07:48 PM
TheJoeY88
Aug 13, 2015 06:51 PM
