New 350 wont run need help bad
Old May 5, 2005 | 09:30 PM
WhoopDang's Avatar
Engine: 350 tbi
First I'll give you the low down on the engine it is a 87 Camaro 350 with 11:1 comp edelbrock heads aftermarket chip new accell 26lbs. h injectors adjustable fuel psi reg. the cam is a 214 224 @.50 hyd. flat tappet cam buget wouldn't let me buy roller cam but i did put in proper tappets and rods. I allso have timing gears. The problem im having is it wont idel and back fires through intake and get really hot fast iv checked all of the easy stuff like timing making shure all the plug wires are on right. I don't think its a vac. leak but i might be wrong. allso is there a difference between the distrubter gear on my stock unit and one that would be used on a older distrubter like my cam is made for?
Old May 6, 2005 | 02:20 AM
Damon's Avatar
Your original (factory roller cam) distributor gear will be jsut fine with an aftermarket flat tappet cam. No worries there.
Bad idle is usually one of two things if the combination is otherwise well-matched:
1. Vacuum leak(s)
2. One or more valves adjusted down too far and holding them up slightly off their seat(s).
Old May 6, 2005 | 08:00 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Re: New 350 wont run need help bad
Sounds like a timing issue to me. I'm assuming this is a carbed motor? My guess is if it fires up and runs that your base timing is close enough, and if the motor gets hot quick, IE: headers get very hot very quick you need to advance your timing a bit more.
Old May 7, 2005 | 01:56 AM
WhoopDang's Avatar
Engine: 350 tbi
valve lash is ok and its a fuel injected could advancing my timing gears 2 Deg. or more help? just in case your woundering the spot i have the timing is the only spot it will even start at.
Old May 7, 2005 | 08:36 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
go back to #1 TDC and make sure the rotor is pointing towards the #1 cylinder. it sounds like you may have the timing off a bit.
Old May 7, 2005 | 08:56 AM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Hmm, I think I would start with mw66nova's idea. go back to base timing and make sure its correct. I would get a good shop manual and follow their suggestions starting from distibutor installation.
Old May 7, 2005 | 09:45 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
are you absolutely sure you got the timing gears lined up right?happened to me once with a cloyes tru roller chain.that one was a mother to figure out!
Eric
Old May 13, 2005 | 11:15 PM
WhoopDang's Avatar
Engine: 350 tbi
fixed
found out why it was running so bad it turns out it was the mass air flow sensor but thanx for all your help guys
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Bradsaundry
Aug 12, 2015 12:34 AM
