Car stalls out after battery disconnected/alternator changed
Old May 9, 2005 | 02:22 PM
1BadGTA's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
My '92 'bird has a quirk that I can't figure out. Whenever I disconnect/reconnect the battery and take her out for a drive, when I slow down, the RPMs' drop and she stalls sometimes. Now when I slow down I have to throttle her a bit while braking so she doesn't choke out on me. This happened a couple years ago when I changed the battery, and most recently when I put in a new alternator. After about a month or so the prob goes away and she returns to normal. Could there be carbon buildup that's causing this, or what?
Thanks for the help.
Old May 9, 2005 | 04:22 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
my car does the same thing. When you disconnect/reconnect the battery it resesets the computer it will take a few weeks for the computer to relearn everything.
Old May 9, 2005 | 11:42 PM
1BadGTA's Avatar
Engine: 5.7 Liter
What causes this? It sucks because, I was making a turn the other day and it stalled out on me, so I lost power steering. Fortunately there wasn't a car in the other lane.
Old May 9, 2005 | 11:46 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
shot in the dark but try cleaning your battery terminals.
Old May 9, 2005 | 11:52 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
it should have relearned by the time you had 50 miles of driving.
try this, start it up, step on the brakes & put it in reverse, hold the rpm up a little if you have to, 1000 rpm or so should be enough, slowly let up on the gas petal until you are completely off of it, let it idle like that for about 5 minutes.
Old May 10, 2005 | 12:11 AM
1BadGTA's Avatar
Engine: 5.7 Liter
It's not the battery terminals, they're clean. The problem will eventually go away but it takes weeks, or maybe a month. I just makes it so that I can't disconnect the battery, or I'll run into the same problem again. I need to figure out why it does in the first place, so I can remedy the problem. Thanks for the input gents.
Terrell351
Jun 13, 2021 01:13 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
