Problems with Engine Swap
Old May 10, 2005 | 05:58 PM
DakotaSLT's Avatar
Hey fellas, I just finished replacing the engine in my 91 RS, and I'm having a bit of trouble. The car will barely start, and if it does, it never gets above 600 rpms, I need to lightly press the gas to get it to fire, once its running I can put my foot to the floor or completely let off and it just sits chugging at 600 (won't rev AT ALL), then stalls out after about 10 seconds. I know its getting fuel and spark, because we've had a flame fire out of the manifold once. That was exciting. Any idea what it could be? Fuel filter? There is ****-tons of fuel getting into the TBI, so I was doubting it. It still backfires occasionally. If the distributor was 180* off, it wouldn't start, correct? Any help would be greatly appreciated, as I'd like to finally drive this car.
Old May 10, 2005 | 06:31 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Did you buy/build the engine? Set the valve lash set correctly? What cam are you using?
Old May 10, 2005 | 06:51 PM
MikeS's Avatar
You may not have your timing set quite right to get it running smooth enough to warm up and set the base timing exactly where you want it. Have you thrown a timing light at it yet?
Old May 10, 2005 | 06:57 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Timing
Old May 10, 2005 | 07:19 PM
DakotaSLT's Avatar
The engine is just another 305 TBI out of another Camaro. It ran when it was in the donor car.
I tried a timing light, its a bit difficult when the engine only runs for 10 second intervals, but it read roughly 2* advanced.
Old May 10, 2005 | 09:41 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I'd try moving the distributor around alittle to see if it will run better.
Old May 10, 2005 | 09:43 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Leave it slightly loose. Have someone fire it up and turn the distributer a little with the engine running. You can only do 1 of two things, make it run better or make it run worse.
Old May 10, 2005 | 10:13 PM
DakotaSLT's Avatar
Good idea, unfortunately one we already tried. I think, but am not sure, that I may have been an idiot and put the distributer in backwards, although I thought I had been careful not to. I'm going to spin the engine to 0* TDC tomorrow with a breaker bar and double check. I
It would make my day if it was that easy a fix.
Old May 11, 2005 | 12:19 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
If you find TDC on #1 make sure you time off of number 6. Or find TDC of #6 and time off #1.
Old May 11, 2005 | 12:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
#1 and #6 are at TDC at the same time. The trick is finding out when they're at TDC on the firing stroke.
Old May 11, 2005 | 05:58 PM
DakotaSLT's Avatar
Fixed! Found a loose vacuum line. Mwah-ha-ha. Took it for a break-in cruise this afternoon with the top down.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
