Anyone running a CompuCam 2032 cam in L98??
Subscribe
Aug 20, 2001 | 03:48 PM
I am running a CompuCam 2032 cam in my Pontiac L98 and I am not getting that much better horsepower difference from the original roller cam. Has anyone else had better luck with this cam. Look at signature below for additions I have made with cam. I am thinking about swapping cams for something larger maybe????? I was looking for about 400HP and more torque but it does not feel that way at all.
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires, 2500 stall, servo and TransGO.
Reply 0
Aug 20, 2001 | 04:22 PM
Sounds about right, that cam is puny. You're not going to see much improvment over stock.
Reply 0
Aug 20, 2001 | 04:26 PM
Any recommendations Jester on cam replacement?
Reply 0
Aug 20, 2001 | 04:28 PM
There are literally dozens out there that would work nicely. If you plan to keep the stock long runner setup (not convert to a miniram or anything down the road) then I say go with the LT4 HOT cam.
Reply 0
Aug 20, 2001 | 04:31 PM
Where can I get specs and prices on this LT4 Hot cam?
Reply 0
Aug 20, 2001 | 04:34 PM
http://www.sdpc2000.com/cart.asp?act...d=993&pid=1900
Reply 0
Aug 20, 2001 | 07:25 PM
Looks like that page is down right now. Keeps coming up with an error.
bsa
Reply 0
Aug 20, 2001 | 07:33 PM
Its 218/228 duration at 0.050", and .492/.492 lift with 1.5 rockers, .525/.525 lift with 1.6 rockers, 112 LSA. Looks like its $175 from Scoggin-Dickey. Pretty good deal if you ask me.
bsa
Reply 0
Aug 21, 2001 | 06:37 AM
It's up around $500 in a kit with Al 1.6 rockers, springs and retainers...
The 2032 isn't that bad on duration but lift is kinda weak for a decently built motor, especially with 1.5s. It's only around .450/.460 IIRC...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Reply 0
Subscribe
