install of new distributor
Old May 23, 2005 | 05:40 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
The paper that came with my new distributor says to be sure that the wire terminal post that is aligned with the rotor leads to the number one cylinder. What is this for? What if you dont do it?
Thanks.
Old May 23, 2005 | 05:46 PM
5.8L Camaro's Avatar
Car: 1988 Camaro
Engine: 350 V-Eight
Rotate the engine to Top Dead Center before installing it. That way it will be on the #1 cylinder, and the distrubitor will also be right on #1.
Old May 23, 2005 | 08:17 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
thank you sir.
Old May 24, 2005 | 06:27 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I put in the distributor and hooked it all up with the connector pugged in just like in the picture and the ignition wire in the BATT terminal. It will not start. It just keeps truning over, but no start. It will only start if I run the MSD 6A too. The ignition wire has 12 volts too. I cant figure it out.
Old May 24, 2005 | 07:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What make and model distributor is it?
Old May 24, 2005 | 07:47 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
It a 93440806 H.E.I. Distributor from the high performance GM website.
Old May 24, 2005 | 07:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
So with the module installed, it doesn't work, but if you remove the module and install the harness for the MSD 6A then it does?
Old May 24, 2005 | 07:59 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Yes. It was the same way with the MSD pro billet HEI I just took out.
Old May 24, 2005 | 08:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Bad ground to the distributor?
Old May 24, 2005 | 08:05 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I guess it could be...I thought it was grounded internally. I could probably hook up an external ground, huh?
Old May 24, 2005 | 08:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Normally it should be grounded through the ground terminal on the cap.
Old May 24, 2005 | 09:23 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
The ground terminal is the middle "prong" where the attached lead fits in. This crap has me confused.
Old May 24, 2005 | 09:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I was just thinking of the coil, sorry. The whole unit should be grounded to the engine through the body.
Old May 24, 2005 | 09:49 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I feel like Rummy looks.
Old May 24, 2005 | 10:56 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I thought if you find TDC of #1 that you timed off #6. Wait...that is if you install your timing chain dot to dot correct?
I haven't done this in a couple years so I have forgotten. I have to do it tomorrow so I better get it straight.
Old May 24, 2005 | 11:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ignition is always timed off #1 TDC firing. The timing chain has nothing to do with it.
Old May 24, 2005 | 11:41 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
If the ignition wire is getting 12v and the dist is grounded, what would make it not work??? Anyone got a clue?
Old May 24, 2005 | 11:54 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I just thought about the tack wire still hooked to the 6a box. Would that cause the distributor not to work on it's own?
Old May 25, 2005 | 12:18 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No
Old May 25, 2005 | 12:37 AM
Transmission: 4l60e
Ok what I was thinking was that if you find TDC of #1 and you line your timing chain up dot to dot that your rotor would actually be pointing to #6. And if you line you dots up at 12 oclock then your rotor would be pointing at #1.
Is that even remotely correct? I could swear I have went by that before and it worked. If its not true I wonder where I heard that from.
Old May 25, 2005 | 12:54 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
When the crank dot is at 12:00, the #1 and #6 cylinders are both at TDC. When the cam dot is at 12:00, the cam is at the #1 firing position. If they're both at 12:00 at the same time, the rotor is pointing at the #1 terminal. If the crank is at 12:00 and the cam is at 6:00, the rotor is pointing at the #6 terminal.
Unless you're going to go and tear the timing cover off every time you mess with the distributor, forget about the dots.
Old May 25, 2005 | 12:56 AM
Transmission: 4l60e
hmm...I just installed my chain dot to dot. Now to see why my rotor points...should I make that #1 or #6. I'm paranoid because I don't want a backfire...I have no desire to change a power valve right now.
Old May 25, 2005 | 12:59 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It doesn't matter. Turn the crank over a full turn and you'll magically convert it to top to top.
Old Sep 11, 2005 | 01:47 AM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Jesus...new cars are so much easier to own.
Old Sep 11, 2005 | 03:44 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If you don't make a point of putting the distributor in on the compression stroke TDC of the #1 piston then, you have a 50/50 change of it starting on the first try. If it doesn't just pull the distrbutor and put it in 180° from where you pulled it out, and try starting it again.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
