No power in CL, when ECM enters BLM it relearns itself to performs WORSE! HELP!!
Old Aug 20, 2001 | 05:26 PM
Xenodrgn's Avatar
For a while there I had accepted the fact that my car was slow, but the 13 MPG bothered me... well today (and other times too) the car sat all day and when I started it and pushed the pedal back, it pushed me to the seat! The TR was great and it had power.. the power I would expect... and then it warmed up, and turned into the sloppy POS it is...
Also, when I reset the ECM and start it, it'll PURR! Idles great, accelerates real smooth, ect. And then I shut it off, start it and it'll be back to it's normal self... Yes I know I'm 'learning' the computer correctly... Varied driving, no WOT, ect...
I thought the low gas milage was a weak spark because the plugs are fouled. I don't think the mix is off because when started in FDM the light stayed on as much as it stayed off (in the 3 second cycle of time) except for WOT it stayed on (WOT enrichment mode?) Unless of course the O2 sensor thinks the mix is right, but it's brain is messed... so it tells the ECM it's right but in reality it's off... the O2 is new, however 2 bottles or injector cleaner have gone through, as well as a two week long anti-freeze leak right on it... I'd like to keep thinking the O2 is good because the threads are stripped and it's welded in there, I'd need to take it back into the shop to get it fixed. And that costs $$ which I don't have.
So with all that info... what kind of guesses can you make? As always, thanks for your help.
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Aug 21, 2001 | 10:32 AM
Xenodrgn's Avatar
TTT
Old Aug 21, 2001 | 09:50 PM
GTA88's Avatar
I don't have an answer to your q, but I can commiserate. My car runs faster with the MAF disconnected. But I can't stand that SES light, so I keep the maf hooked up....
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Aug 22, 2001 | 12:04 AM
drive it's Avatar
We need some more info...Do you have access to a scan tool? Sounds like with a scan the problem should jump right out at you. Any codes set? If the injectors are sticking open it would pour fuel in and account for the poor mileage-also that would take out the O2 sensor and the cat; but that rich or the O2 sensor fried it should set a code. Does the check engine light ever come on? Is it burned out?
86 406
Old Aug 22, 2001 | 11:10 AM
Xenodrgn's Avatar
This is on the funny/ironic side... the only code I got was a lean O2... I only got this code while running injector cleaner. (The STP Black bottle)
No I don't have access to a scan tool... only a paperclip.
Here is what I'm thinking;
1) Either bad computer or ignition module
or
2) Bad ignition coil and bad O2 sensor. (or possibly other bad sensors...
So with that info, can you figure anything else out? The power change between open loop and closed loop is so dramatic, I enjoy driving the car in open loop, but I don't want to beat on a cold engine and put unneccary wear on it...
Old Aug 22, 2001 | 10:15 PM
Xenodrgn's Avatar
TTT again. C'mon, I know other people have had this problem, but the posts in the archives never came to a conclusion.
Old Aug 23, 2001 | 12:12 AM
drive it's Avatar
[QUOTE]Originally posted by Xenodrgn:
[B]This is on the funny/ironic side... the only code I got was a lean O2... I only got this code while running injector cleaner. (The STP Black bottle)
or
Yes a bad O2 sensor could do it- however a bad ignition coil would effect it the same in open loop. Sorry, but we really need some scan data! An auto x-ray 240 costs about 200.00 with a cable- I know its not change but it is invaluable for any trouble shooting; and it's cheaper than diacom. If you lived near southern calif. I'd say bring it by-I'd be more than willing to scan it with diacom!
86 406
Old Aug 23, 2001 | 12:19 AM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by drive it:
An auto x-ray 240 costs about 200.00 with a cable- I know its not change but it is invaluable for any trouble shooting</font>
I'm asking for one for Christmas...
<font face="Verdana, Arial" size="2">Sorry, but we really need some scan data! </font>
What would you be looking for in the scan data? Maybe I could get my hands on one... it'll take some working on though, I don't know.
Old Aug 23, 2001 | 10:55 PM
drive it's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
What would you be looking for in the scan data? Maybe I could get my hands on one... it'll take some working on though, I don't know.</font>
First things to look at:O2 cross counts(look for fast transitions above and below 450mv.), BLM, INT(look for 128), spark advance and spark knock(how much).....
86 406
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
stalkier
Aug 13, 2015 12:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
