Gas milage
Old May 23, 2005 | 10:42 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Gas milage
I got a 305 sb carbved.. and its a gas hog. i ease in to the gas and ease form starts.. the only time i ppush it is when ricers come next to me and wind up there toys. then i show them a real car. Anyway to get better gas milage outta it?
Old May 23, 2005 | 11:41 PM
ManoftheHour's Avatar
full tune, try making sure timing is set correctly, fuel filter. the works.
then after that weight reduction.
carb is really hard in the first place to help with fuel effiency.
Might want to go EFI....
MTH
Old May 24, 2005 | 12:14 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
its a new engien and its been tuned as well as it can be. efi is expensive. im just looking for some quick fixes
Old May 24, 2005 | 12:34 AM
mars22's Avatar
Car: 83 firebird s/e w/ttops and a/c
Engine: 2.5 iron duke/ tech IV
Transmission: 5 speed
look into electric accsories! some say it cant be done but i say they are obviously wrong .it should get you at least 5 more mpg.
Old May 24, 2005 | 03:01 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
https://www.thirdgen.org/techbb2/sho...hlight=biochem
Old May 24, 2005 | 03:16 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
what kind of mileage are you getting? any mods done to your motor?
my old dead stock 305 with its 4 barrel carb would do 17~18 highway 15~16 city with everything perfectly right, most of the time it got around 16 highway 14 city.
after i put in the 350 with a mild cam it would on occasion hit 20 highway & 17 city, if i was very light on the gas. most times i was lucky if i got if i got 18/14.
those Q-jet carbs are decent carbs,.. but trying to get them tuned perfectly dead on is a pain.
those are some killer mileages they posted there
street,.. i think i had the wrong cam in my car.
Old May 24, 2005 | 03:32 AM
mars22's Avatar
right now its getting squat for milage, especialy with the a/c on,like 5/10 city/hiway, but that was with a bad clutch and bad fluids and filters and alot of the emmisions stuff realy messed up.but i have fixed all that and want 35 hiway and 25 city, with a/c, but the electric mower is $129 and a converter is $75 plus batt and cables $50 ,so it shouldnt be that much to get it going.
Old May 24, 2005 | 07:54 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
yeah its bone stock. o get like 10 city. kinda sad i dirve less than 2 miles to school an din like 3 days im down a quater of a tank
Old May 24, 2005 | 08:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Full tune-up obviously; make sure you get it all working right.
The most usual cause of terrible gas mileage, is the plugs in the base of the carb leaking. There are 4 spun-in little plugs, under the primary jets; they have fuel on top, and vacuum on the bottom. If there's a leak, which there usually is from dissimilar metal electrolysis, the engine just sucks gasoline right out of the fuel bowl. If your car is hard to start first thing in the morning, then you probably have that going on; the hard starting is caused by all the fuel draining out of the carb through the leak. The cure is to take off the carb, sand and wire-brush the metal alll around the plugs to completely fresh rough material, sterilize it with lacquer thinner or something, and epoxy over them.
It should get 14-15 city and 22-25 highway, depending on what gears you have.
Old May 24, 2005 | 11:49 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
its a new engine and carb..
Old May 24, 2005 | 11:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What kind of carb?
Old May 24, 2005 | 12:28 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
edelbrock 4 bbl... itrs been tuned for the best gas milage
Old May 24, 2005 | 12:39 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OK, so it's not
bone stock
if it's got that Carter on it.
That's a good clue to your gas mileage problem right there.
DO you have a non-computerized distributor on it, with centrifugal and vacuum advance? or is that still "bone stock" too?
Old May 24, 2005 | 12:41 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
vaccum i beleive
Old May 24, 2005 | 12:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Did you change it?
Old May 24, 2005 | 08:13 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
it came with the car.. all i know is that it is new and has less than 500 miles on it
Old May 25, 2005 | 01:59 AM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Well...IF you have a vaccum/centrifugal distributor than you need to find a way to lock up your torque convertor if you haven't already. I wired up a vaccum-openerated torque convertor lockup switch to mine and saw a noticable improvment in gas mileage.
Old May 25, 2005 | 09:07 AM
contact's Avatar
Engine: sbc 350
Is the {distributor} vacuum advance working?
Old May 25, 2005 | 10:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
So this motor was built by the previous owner 500mi ago? Nothing is stock anymore then eh? Is it even a 305? what other accessories are on it? If you drive it hard, which it sounds like you do, that mileage is normal.
Old May 25, 2005 | 11:56 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
its a remanufatctured by oreillys. has everythigna normal engine woul dhae...
Old May 25, 2005 | 01:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Gotcha, so a rebuilt 305, but with an edelbrock carb? And a non-cc dist? Everything else stock?
Did Oreillys build the engine totally? or did someone else add the carb/dist? If they built it completely, we can assume it's the correct dist...
Then leave your foot off the gas! Aside from that, fuel filter and proper tuning of the carb and making sure you're getting good spark is about all you can do.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tonys91rs
Oct 10, 2015 03:31 PM
PestilenceIV
Sep 22, 2015 07:39 PM
reactor60
Sep 22, 2015 01:44 PM
