help with timing
Old May 24, 2005 | 12:06 AM
88Z's Avatar
88Z
Car: 88 Iroc
help with timing
I swapped out my manifold over the weekend. After installing the distributor back what i thought was the original position, my car is beyond gutless. Thinking i set my distributor wrong, it seemed like it was retarded badly. After getting out my timing gun and advancing it 6°, shouldn't i expect it to be right at zero? At any rate, it was completely off the timing tab past all of the advancing marks! If it's that far advanced shouldn't it be pinging like crazy? I have no idea what's going on with this thing.
Old May 24, 2005 | 05:01 AM
ede's Avatar
ede
did you unplug the est?
Old May 24, 2005 | 11:11 AM
88Z's Avatar
88Z
Car: 88 Iroc
No, i took it for granted i'd be putting my dist right back in the same position.
Old May 24, 2005 | 12:18 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
unplug the EST and then set the timing.
Old May 24, 2005 | 01:50 PM
88Z's Avatar
88Z
Car: 88 Iroc
Just so i'm clear, if i set the gun to 6° advanced it should hit right on 0, right?
Old May 24, 2005 | 01:54 PM
88Z's Avatar
88Z
Car: 88 Iroc
i mean as far as advancing my timing 6 degrees
Old May 24, 2005 | 02:13 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I've never used an adjustable timing light before, but I'd assume that's what you'd do. I just have a cheapy that flashes itself at spark.
Old May 24, 2005 | 02:33 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
If your setting it to 6* advanced, then yes, the mark should be on zero... but the ESC MUST be disconnected to set the timing regardless.
Old May 24, 2005 | 08:17 PM
88Z's Avatar
88Z
Car: 88 Iroc
Yeaaaah i get that, but i haven't done that yet because i thought i was installing the distributor and rotor to the exact same position. I KNOW the timing was set at 10° advanced before though, guess i'm not so good at restoring things! Nevertheless, with timing advanced so drastically shouldn't i be getting some serious ping? The wrench for this is finally coming in tomorrow morning, so i'll mess around with it and see what happens.
Old May 25, 2005 | 09:34 PM
88Z's Avatar
88Z
Car: 88 Iroc
Well, i got my timing advanced 6° and....my car's still running like a gutless wonder. My fuel pressure is at 45 with everything connected, so i'm thinking it's my TV cable. I set it by going to WOT and pulling the slider back. The thing is that i didn't get a chance to feed it back under the plenum before i slapped it back on, so it's going into the bracket area of the cable housing at a weird angle, although it seems to be getting fed through all right. What else could it be with just an intake swap?
Old May 30, 2005 | 10:52 PM
camarocruzin's Avatar
Car: '89 Iroc
Transmission: 700-r4
bump..somebody please help me/him im having the same problem after an intake swap, 88z did you figure it out?
Josh
Old May 30, 2005 | 10:59 PM
88Z's Avatar
88Z
Car: 88 Iroc
Well, it turned out that the back of my tv cable was actually pulled out of the adjuster's housing. After going and buying a brand new one, it turned out that the old one could be snapped right back in! After adjusting it, it's now running like a monster. I would probably guess it's tv related if all you did was the intake and your timing is on.
Old May 30, 2005 | 11:08 PM
Car: '89 Iroc
wow i didn't know the tv could cause such issues, i forgot to route mine under the runners as well, but with some force and luck i got it back under the runner, but maybe i messed it up on the back, where does it mount exactly?
Old May 30, 2005 | 11:11 PM
88Z's Avatar
88Z
Car: 88 Iroc
I don't get what exactly you're asking. Where does what mount? The TV cable to the housing?
Old May 30, 2005 | 11:15 PM
Car: '89 Iroc
sorry, im really oblivious to the function of the cable, i got it hooked up to the tb correctly, but not sure where it goes once it "disapears" behind the engine, was curious as to what to check at the other end, to see if i broke somethin
Old May 30, 2005 | 11:26 PM
88Z's Avatar
88Z
Car: 88 Iroc
it's bolted down to the passenger side, top of the oil pan area. It's pretty hard to even see it. If the loop from the tv cable came off or broke off of the hook in the tranny, you should be able to pull your tv cable way past your throttle body. That's probably the easiest way to check if everything there is ok, although there may still be a problem. What kind of intake did you swap to? Did you try adjusting the cable?
Old May 30, 2005 | 11:38 PM
Car: '89 Iroc
just reset that cable, pushed in the side of that thing then opened it up wot(it clicked, and set) can't start it tonight, didn't swap to anything, this was purely to stop the mess i was beggining to leave on the driveway
Old Jun 1, 2005 | 12:16 AM
Car: '89 Iroc
prolem solved, found a HUGE vacuum leak at one of the runner to manifold points due to a pinched gasket (little pin you push into the intake popped out when setting the runner on) all seems to be well now
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
