Steering wheel on angle
Old Aug 26, 2001 | 01:55 PM
reborn's Avatar
When the wheels are pointing foward the top of the steering wheel is around 1'oclock.
What caused this and is it a big deal to fix?
Old Aug 26, 2001 | 02:09 PM
87tpi420's Avatar
either whell was takin off and not put on straight or you more than likely need an alignment
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Aug 26, 2001 | 03:37 PM
reborn's Avatar
An allignment? I didnt think that it could get that bad and just need aligning.
Anyone have any other ideas?
Old Aug 26, 2001 | 03:58 PM
Xenodrgn's Avatar
Mine does it too (mine is at about 2 o'clock) and I saw another Camaro who's was turned at about 1 o'clock. Get an alignment, drive it home, pull the wheel and put it back on straight. They can 'walk' over time... The only thing is, you're going to need a wheel puller, these things are on there. (thats the only reason why mine isn't fixed yet.)
Old Aug 27, 2001 | 08:51 PM
reborn's Avatar
Your talking about the steering wheel that needs to be taken off and back on right? I was looking at the manual and I dont know how that fixes anything. Is the shaft it fits onto toothed so that it can be adjusted?
Does anyone have any pics either real or from a manual, the one in the hayes isnt all that clear.
Thanks for the help, driving gets a little wierd with this wheel lol
Old Aug 27, 2001 | 09:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IIRC the wheel is keyed, only goes on one way.
Get an alignment. Being off that little is really tiny, it may even be less than one turn on the tie rod sleeves (that is, if they adjust them one turn, it may be off by more than that, the other way)
ICON Motorsports
Old Aug 27, 2001 | 11:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Make sure you tell the alingment shop you want the wheel centered when the job is done.
If you're absolutely sure your alignment is okay, then you can adhust the tierod ends yourself...whatever you do to one side, do the opposite to the other..i/e you turn one side in a 1/2 a turn, you'll need to turn the other out a 1/2 a turn.
Old Aug 28, 2001 | 12:14 AM
91RSconv's Avatar
when I did my headers my friend took off the steering shaft and didn't mark it right for reassembly now I have the same problem but it can be fixed by doing what he did but in the reverse order with a little trial and error
SlowAZ28
Aug 31, 2015 07:56 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
