what a good engine building book?
Old Jun 1, 2005 | 09:17 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
just curious what others think is a good book. need something that steps you through putting an engine together from scratch- something that lists all of the clearances and such.
Old Jun 1, 2005 | 09:54 AM
USMC3782's Avatar
Car: 86 TA, 00 Z28
Engine: L31 Build in Progress
Transmission: NWC T5 till it blows
Books
I am reading two right now, Chevrolet small block parts interchange manual, by ed staffel. and how to build max performance chevy small blocks on a budget by david vizard.
Pro/Cons
The parts interchange manual is excellent. It has tons of useful information, only thing i wish they went more in depth on, fuel injection...
The vizard book, once again excellent basic knowledge. Assumes you can port heads and do your own machine work. Also assumes everyone on the planet loves carbs and his engine builds reflect this.
BAsically they are great for basic knowledge, and once you can input your fuel injection cfm and other factors you can use these books to learn a bunch.
Just my .02
Old Jun 1, 2005 | 07:10 PM
brutalform's Avatar
John Lingenfelter on Modifying SBC Engines. It covers many tips, tricks, and engine theory. Also the Chevrolet Power Manual.
R.I.P. John.
Old Jun 1, 2005 | 11:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I have "how to rebuild your SBC" by David Vizard, and i'm less than impressed. It's fairly outdated it seems, and it focuses a lot on re-using parts that I would guess would normally be replaced.
Old Jun 2, 2005 | 06:44 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
well- crap. I am not really looking for one of the "tips/tricks" books- i want a how to book. and so far- the only one the people know of sounds as though it sucks. well- guess i will keep shopping. thanks for the input though.
Old Jun 2, 2005 | 10:21 AM
brutalform's Avatar
One book might not be what you are looking for. Maybe take a couple of books. I have a small library here. I agree about alot of the books being outdated. I have an old "How to hotrod SBCs" and they say that roller rockers are a waste of money, and are for "RACING" only. Go figure.
Old Jun 2, 2005 | 10:41 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
well- all of us "race" at one time or another don't we?? i guess we had better be prepared
Old Jun 2, 2005 | 12:03 PM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
I liked this book:
"How to build the smallblock chevrolet" SA design
by Larry Atherton and Larry Schreib
Goes into good detail and tons of pictures.
Old Jun 2, 2005 | 12:26 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
might have to see if the local Borders or Barnes/Noble has that- thanks
Old Jun 2, 2005 | 02:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by Thomas Aquinas
I liked this book:
That one's pretty good for mostly stock-type rebuilds, but if you want to be modifying things you might also pick up "Engine Blueprinting" by Rick Voegelin, also from SA Designs.
Old Jun 2, 2005 | 02:39 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
like i said before- the main things i am looking for are torque specs and clearances for putting the short block together and bolting everything up. i already have my engine combo lined out/purchased. both of those seem to fit the bill. now i get to spend more money
Terrell351
Jun 13, 2021 01:13 PM
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
