i have a really bad feeling about this!!!
Old Aug 29, 2001 | 07:19 PM
sunbound's Avatar
Car: 1987 IROC-Z
i had the intake manafold bolts in the holes so i knew where to find them... when taking one of them out, i lost my grip on it, and it went down the whole the distributor goes down in.... i have a very bad sinking feeling that i am royally $crewed!
i put my finger in the to see if i could feel it, and all i felt was the cam... is their an easy way to get this out?
i just got the engine in last week, and i really dont want to have to take it back out...
jon
Old Aug 29, 2001 | 07:24 PM
simon's Avatar
Try using a magnetic pick up tool, or the one with the expanding claw. They have them at most parts stores.
Old Aug 29, 2001 | 07:35 PM
AustinT's Avatar
Do what Simon says,
I lost a bolt in the dist hole and retrieved it with one of those magnet things. The hardest thing is the magnet trys to stick to everthing else on its way down the hole.
Old Aug 29, 2001 | 07:38 PM
sunbound's Avatar
Car: 1987 IROC-Z
their is still a problem with that.... i cant even see the damn bolt... i see the timing gear, and thats about it....
damn do i feel stupid....
Old Aug 29, 2001 | 07:51 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Is the iol pump shaft installed? If not, and you can't see it at all, it may be in the lifter valley. The magnet pick up would work best for this. Just a thought.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I hear ya! I did the same thing once. I had to take the intake manifold off and the bolt was sitting under the spider that holds the lifters in place. Maybe you're lucky and it didn't fall all the way to the bottom of the engine.
Old Aug 29, 2001 | 07:59 PM
sunbound's Avatar
Car: 1987 IROC-Z
my intake is off.... what does the iol pump shaft look like? if never fully disasembled my engine... all i see is the timinmg gear and some other gear thing....
jon
Old Aug 29, 2001 | 09:01 PM
sunbound's Avatar
Car: 1987 IROC-Z
if i cant get the bolt out with a magnet or claw, what do i have to do to get it out?
jon
Old Aug 29, 2001 | 09:25 PM
camaroguy99's Avatar
I did this not too long ago. You're pretty much pulling off the oil pan. You might be able to get it without lifting the engine but most likely you will have to lift it. It's not [i]that[\i] bad. what if you didn't realize that you dropped the bolt in there. that would be bad.
Old Aug 29, 2001 | 09:27 PM
sunbound's Avatar
Car: 1987 IROC-Z
so i wont have to pull out the cam or the crank? cause THAT is what im afraid of.. i have never dug into my motor that deep, the deepest i ever got was pulling off the heads....
anyways, friday (payday) im gonna go and buy a magnetic or claw tool.
thanx...
jon
Old Aug 29, 2001 | 11:58 PM
rezinn's Avatar
The oil pump shaft sticks up beside the cam gear, the distributor turns it when the cam turns the distributor gear. It is directly down the distributor hole.
Hopefully it is in your lifter valley, if not its probably sitting at the bottom of your oil pan. Now you see why I shove a piece of newspaper in that hole when I have my dist. out.
[This message has been edited by rezinn (edited August 29, 2001).]
Old Aug 30, 2001 | 06:56 AM
sunbound's Avatar
Car: 1987 IROC-Z
yeah, i did that when i had the engine out of the car.... for some reason, i took it out when the engine was in.... i hate details...
thanx guys! im just glad i dont have to pull out the cam or anything.... i dont need to get that deep into my engine.
thanx
jon
Old Aug 31, 2001 | 06:55 AM
sunbound's Avatar
Car: 1987 IROC-Z
got it out in 5 minutes.... i heard a click, looked at the magnet, and their it was....
thanks much for your suggestion, here i was freaking out over something stupid.
jon
TheTraut88
Sep 11, 2015 05:16 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
