Car needs to start NOW!
Old Jun 6, 2005 | 07:25 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Well I'm in the middle of painting my Camaro. Went back to the shop today and found that it no longer runs! Saturday it ran fine. Took it to the shop did body work, washed the car (engine got wet), and then parked it. Came back on Monday (didn't do anything Sunday) and the car won't start. It's trying to start, like it's revving up. But it won't turn over. And if you crank it long enough, you can smell gasoline (seemingly from the back of the car). What's wrong? The shop is too far away to have it towed home, and I blew all my money on paint, so I can't afford to take it anywhere else. I need to get it out of the shop!
P.S: It's a 92 Camaro RS with an LO3 and 700-R4.
Any ideas...?
Old Jun 6, 2005 | 09:04 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
take the distributor cap off and check to see if water got into it
if so dry it out and spray wd 40 in it
Old Jun 6, 2005 | 09:25 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I'll try it first thing tomorrow. Thanks a lot.
Old Jun 6, 2005 | 10:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
WD-40 is flammable for a period of time after its been sprayed so it may not be the best thing to use around an open spark. A good, clean rag will be best. Wipe all the parts dry and maybe follow up with some compressed air to carefully blast out any remaining water.
Old Jun 7, 2005 | 03:19 AM
isn't there a water displacement spray that isn't flammable then?
Old Jun 7, 2005 | 05:12 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
LPS #1 works good. but it is also some what flammable, but not as much as what WD40 is.
my recommendation is to spray it down first & then thoroughly blow it out with compressed air.
Old Jun 7, 2005 | 05:10 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
You guys think it might be the fuel pump? That seems to be the general opinion here. But it was working fine before I parked it.
Old Jun 7, 2005 | 08:28 PM
DENN_SHAH's Avatar
it could be the fuel pump, its not uncommon for them to work fine & then not work on the next start up. hang a pressure gage on it & see what you have.
Old Jun 7, 2005 | 09:27 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
but he has the gas smell
Old Jun 7, 2005 | 10:10 PM
IonNight's Avatar
Car: 1986 Iroc Z
Engine: Truck 305 /Bored .30 Flat Pistons/ Crane Cam
Transmission: Corvette 700R4
check the battery ground that can cause the car to not even try to turn at all
if not check battery look for something that might have came loose/check fuel pump fuse
Old Jun 8, 2005 | 08:39 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
P.S: Thanks a lot for all the suggestions.
Old Jun 9, 2005 | 04:54 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Re: Car needs to start NOW!
I don't understand what you mean by its revving up but not turning over? You mean its not firing but the crank is turning over? If it is not firing check your coil wires and also under the cap. Then I would check the other connections and the battery power and grounds.
Old Jun 10, 2005 | 03:03 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
It runs! We changed the spark plugs and that fixed it. Thanks a lot guys.
Old Jun 12, 2005 | 08:40 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Some newer types of brake cleaner. Read the can, it will say flammable or non flammable. I was dumbfounded when I discovered that. I was trying to scorch out a paper wasp nest in my shed. Three times my can of brake cleaner blew out the flame of my lighter before I read the label on the can.
You can thank the environazi's for that. It's because of them we have nonflammable, CFC free brake cleaner that won't clean **** off anything anymore.
Old Jun 13, 2005 | 10:22 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Those Bastards!
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
