Massive Problems With Moron's IROC
Old Sep 1, 2001 | 12:04 PM
slowV8berlinetta's Avatar
An acquaintance of mine has an '87 IROC, 305, TPI, 160,000, auto, and it hasn't been started for awhile. before i got to it, someone told him to replace the ECM, so he did, i told him to change the fuel filter and check pressure and volume, and that was fine. I was told it ran for a few seconds off of ether, but that was probably compression ignition, because there is fuel, and no spark. He replaced the ECM, so codes aren't available, and i can't get spark with a tester. someone told him to replace the coil, but that didn't do anything, and i told him to not bother, i took out his ign. module, and had autozone test it 5 times, it kept on passing. where could the problem be, how can i fix it? any help is appreciated.
'84 Berlinetta, LG4, 700R-4, starwars interior, no major mods yet
Old Sep 1, 2001 | 01:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
bad pick-up coil in the distributer shaft?
Old Sep 1, 2001 | 05:23 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
I agree with Mkos1980 that a bad pickup coil could cause the problems that you are having.
88' IROC-Z, 350 TPI, 700-R4
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
MY87LT
Aug 17, 2015 08:43 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
