Smog/AIR Pump: Who's got one and who doesn't???
Old Sep 2, 2001 | 04:25 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I've seen a few thirdgens without a smog pump and i really want to get rid of mine because it makes noise but I dunno if i'll pass smog. (I guess i could put it back on for testing???)
So, why do some cars not have Smog pumps??? Was it based on the state the car was sold in??
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Sep 2, 2001 | 05:17 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Every one sold in the US had the smog pump factory installed. If you have seen them missing, they were removed by either the current or previous owner. The question that comes to my mind is why would you want to remove it?
"Question with boldness even the existence of a *** ; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Sep 2, 2001 | 06:00 PM
Engine: LH0 3.1L
If they all came with one, how do you explain a bracket with a pulley in place of the smog pump??
Nobody makes that so i was led to believe that it was from the factory. It was on a V6 5 speed, BTW. Maybe all V8's came with them??
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Sep 2, 2001 | 06:04 PM
JETHROIROC's Avatar
One GOOD argument for removing it is underhood appearance and making things easier to service. That's why I took all my AIR system components off. It won't give you any power improvements, but I sure like working on mine a whole lot more now. Just my $0.02.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TB.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Sep 2, 2001 | 06:08 PM
Engine: LH0 3.1L
I want to get rid of it because my original one was making wierd noises so i replaced it. Now, about 1 1/2 years later, it's making noise again and it's really friekin annoying.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Sep 2, 2001 | 06:45 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
The pulley and bracket's there on some of the deleted cars becuase whoever did it felt like buying the SMOG DELETE PULLEY from GMparts, not beacause they came like that. Just figured I'd help. If anyone knows different, lemme know
Old Sep 2, 2001 | 08:44 PM
Engine: LH0 3.1L
Ok, WHY would a smog "delete" pulley EXIST if it wasn't originally available?? I'm having a hard time believing this.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Sep 3, 2001 | 02:57 PM
Engine: LH0 3.1L
Ok, we've got 6 people on the V6 board that don't have a smog pump and they didn't remove it. Maybe only all V8's came with them??
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
[This message has been edited by CaliCamaroRS (edited September 03, 2001).]
Old Sep 3, 2001 | 03:03 PM
iroc5speed's Avatar
mine has the pump, and your theory would make sense as a v6 puts out less amounts of harmful gases than a v8.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Sep 3, 2001 | 03:47 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
As far as I know, all V8 thirdgens had pumps...the reason you can get a smog pump delete pulley is cause most the trucks didn't have pumps on the V8s...this is where the pulley comes from.
Same motor...different pulley/belt set-up.
This is off the top of my head...anyone else?
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited September 03, 2001).]
Old Sep 3, 2001 | 03:52 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
not all cars have them. on my 3.1 Lumina there is no pump. There was a pump on my L98 though which i took off and it still passes e check with flying colors.
Old Sep 3, 2001 | 05:29 PM
82resto's Avatar
Hey, just so you know.. all V8's came with smog pulleys except in the mideast where, of course, GM still makes trucks with 454s, etc, due to their lack of emissions laws. By the by, I took off my smog system and replaced my cats with high flow cats (i don't take emissions tests, therefore it's unnecessary). Since I did that, I've noticed that the rich mixture that caused smoke to come out of my tailpipes when I coldstarted my car has ceased to exist, making me a happy camper. And combined with my anti-A.I.R. headers, changing spark plugs is SOOOOOOOOOO much easier.
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
Old Sep 3, 2001 | 07:14 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by 82resto:
Hey, just so you know.. all V8's came with smog pulleys except in the mideast where, of course, GM still makes trucks with 454s, etc, due to their lack of emissions laws. </font>
Are you talking all V8s?? Or just trucks??
In CA I work on CA certified trucks ALL the time with NO air pump. I also work on 454 trucks.
They haven't made a true "49 state" car/truck in some time. Even all the federal cars/trucks have CA emmisions and smog pumps where applicable.
I do smogs on gov. trucks from all over the country and they all have the smog stuff.
I'm not sure I understood your answer.
As far as the original question, on Thirdgens they all had smog pumps, no matter where they came from. Even my fed. smogged TA had one.
Yes, living in Pasadena, you will need a pump, its part of the visual test.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
gta892000
Aug 11, 2019 11:16 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
evilstuie
Sep 24, 2015 02:31 AM
corey8084
Sep 17, 2015 02:56 PM
