is this bad? a rod main question.
i'm not sure how to do this...
or maybe..
http://members.aol.com/bendoe/1.jpg
http://members.aol.com/bendoe/2.jpg
http://members.aol.com/bendoe/3.jpg
Anyways, those are pictures of the number 2 rod on my forged 327 rotating assemby. On only that main there is a little notch in it, that is machined. The rod main cap has "80C" on it. What is it and is it suppose to be there?
-Ben
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218, 187 head castings with bigger valves, self-burned eproms.
All work done by myself, and proud of it!
SOON TO COME 327 Miniram (3/2002) PARTS NEEDED:Titanium valvetrain parts, stud girdles, fluidampnr, miniram, bulletproof bellhousing, MONEY(im in college).
Find a .bin on the internet and want it burned? I'll do it for you!
or maybe..
-Ben
Car: 4
Engine: 6
Transmission: 5
The notch is an oil spit hole, to lube the piston pin on the opposite bank by squirting a shot of oil at it as the oill feed passage to that rod passes under it as the crank spins.
ICON Motorsports
ICON Motorsports
Is it normal that its only one 1 rod?
Car: 4
Engine: 6
Transmission: 5
No not really. All rods had it up until some year, then they dropped it. No large journal (69-up) motors had it, only the early small-journal motors (like 65 or so on back). All it means at this point is that you have a random bunch of rods rather than a set.
ICON Motorsports
ICON Motorsports
Car: 1989 C4
Axle/Gears: 307
Sweet looking rods, now those I can work with.
Is it a large journal 327? All the LG 327's I have do not have the oil holes, and I have a bunch of them. Muhhaaaaaaaaa
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
hmmmm....
i need to uhhh, "machine" a little off the top of thoes, and perhaps enlarge the center to the next oversize......
Schweeeet!
Most likely, he loaded some different images to the hosting server with the same name. The post IS a couple years old.
Still, "machining" those might be a good idea. What kind of coolant would be best to use?
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
http://www.gtslade.com/lox/moo/yasgotit.jpg
Car: 91 Camaro Vert
Schweeeet!
Schweeeet!
well alot of people like to "machine" thoes with milk/siliva mix
i personally prefer pepsi, but im wierd.
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
