3 RPM max... somethings wrong
Old Jun 11, 2005 | 08:21 AM
pixeldev's Avatar
Car: 88 IROC-Z Conv. Camaro
Engine: V8, 5.7L Supercharged
Transmission: Auto, shift kit
Ok I have a very weird problem. I have a 355 Supercharged. It has a pressure problem with oil coming up the top bolts ( https://www.thirdgen.org/techbb2/sho...hreadid=300567 ) if you want more info. I don't know if that has to do with the problem though.
However, here is my problem. When I am cruising, lets say 2 RPM and I push the gas ALL the way down, it makes a real loud sound that doesnt sound quite right (its the supercharger) and it slowly goes up to 3 RPM and maxes out there, it WONT go above 3 rpm... maybe 3100 rpm...
But when I am at a stop light and floor it from an idle, it goes real high around 5 rpm.
Anyone know whats going on? Here is a pic of my engine.
Old Jun 11, 2005 | 01:18 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Can you bypass the SC to eliminate a variable?
Old Jun 11, 2005 | 02:32 PM
pixeldev's Avatar
Take it out? yes I can do that, not today though... *** its running like a frekin KIA. I was on the highway just a minute ago and I floored it from 1 RPM, it went up to 3 RPM and A FREAKIN MINIVAN WENT PAST ME and we got off the same off-ramp.... something is definatly wrong, shouldnt a 355 SC v8 5.7l engine be able to out speed a minivan? I think so...
Anyways ill prolly do it tomorrow if I have the time. But every time it reaches 3 rpm the supercharger makes an awful noise, so I think that might be it, but can a supercharger really bring down that much HP if its busted?
Old Jun 11, 2005 | 02:34 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't mean remove it off the engine, can you run a bypass belt so the SC isn't working/spinning?
Old Jun 11, 2005 | 02:35 PM
pixeldev's Avatar
Oh,,, I dont know maybe... but wouldnt that still make air flow through it and make the fans spin making it less HP than if it was off?
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd be lucky if you could get it to start then.
Old Jun 11, 2005 | 02:36 PM
pixeldev's Avatar
That's what I thought.... id be like blocking the airflow
Old Jun 11, 2005 | 03:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Change your fuel filter and try again before I'll offer any more suggestions.
Old Jun 11, 2005 | 03:08 PM
pixeldev's Avatar
Ok ill do that, is my fuel filter the one on the side of my holley carb, the summit racing chrome cylander? You can see it in the pic is that it?
Old Jun 11, 2005 | 08:36 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Good point, just read the sig line and see he's carb'ed.
Old Jun 11, 2005 | 08:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Either way, hard to suck air through a stalled roots unless it has a bypass valve.
Old Jun 11, 2005 | 09:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya, I've been long to often into EFI and seeing/hearing guys with paxtons, etc, that bypass them...completely different beast and easy to do so.
Teaches me to yak, then look.
But hey...least I got the poor guys thread started
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
evilstuie
Jan 9, 2020 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
dhonda200
Aug 11, 2015 11:50 PM
