Ripped my PCV valve boot
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I bought new valve covers and my PCV valve boot was ripped while I tried to swap it over. Anyone know the name of the part or where I can get it?
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
If your talking about the rubber gromet that the pcv goes in, in the valve cover; I bought one at pep boys in section were the pcv valves are sold. Maybe paid $2.00 or $3.00 for it.
Car: 1987 camaro, 1994 z28
Engine: 2.8l V6 mpfi, 5.7l lt1 350
Transmission: 700r4 in the 2.8, and t-56 6-speed in the z28
is this the boot that is above the oil cover on the valve cover? cause today my car started to run like **** below id say 3-4k rpms and if i gave it any little bit o fgas below those rpms the car would just like rumble at 500 rpm range, if i give full gas it is fine, so when i checked for leaks i found one hose to be kinked so i cut it alittle shorter (top of motor left side there are 2 hoses going to it one big one small it was the small one with the issue) and put it back, then i noticed that the thing above the oil cap was sticking up a bit so i took it out and i think that its just floating there cause if i push on it it doesnt sit in right is this the piece someone helppp!!! im gonnna post this as my own thread cuase i neeeeeeeeeeeeeeed to get the car back on the road (again) thanks alot guys (again lol)
gta892000
Sep 16, 2015 12:37 AM
