Whats going on with my engine? Anyone?
Old Sep 5, 2001 | 04:50 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
My temp constantly fluctuates, my air/fuel ratio constantly fluctuates too. Engine has 179k and has a new MAF, and just about every sensor known to man. has a complete msd ignition, etc. Ideas?
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 5, 2001 | 10:43 PM
FlashGTA
Guest
Posts: n/a
I would suspect computer problem.
Old Sep 5, 2001 | 11:04 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Did you change the O2 sensor? That would cause the fluctuation in the Air/Fuel reading if it were bad. Other than that, maybe the ECM is going south?
Old Sep 5, 2001 | 11:06 PM
o2 sensor probably has.. o... 6k on it. I replaced it december last year and didnt drive the car for at least 4 months.
See my car Here!
Old Sep 5, 2001 | 11:10 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by FlashGTA:
I would suspect computer problem.</font>
Dido! It sounds like you car wants to be a dodge. try another ecm.
SSC
Old Sep 5, 2001 | 11:12 PM
Sweet... thanks for your help guys, as a side question, im assuming this would hurt fuel economy and performance? My MPG is like 10 mpg in the city and sometimes on freeway ill get like 30 mpg then 8mpg...
700r4--&gt;t5 w/ram clutch
See my car Here!
Old Sep 6, 2001 | 12:15 AM
Old Sep 6, 2001 | 11:12 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Graeme'sFirebird:
</font>
Yes, This is a common problem with dodges "where most of my experiance is with computer problems" The ecm will filcker between cold start and warm run or just totaly think the A/F is lean and start pumping gas down it like crazy.
Try to get an ECM that is complete. One that came from an exact twin so to speak so you dont have to reuse any of your old computer parts. This should eleminate your problems.
SSC
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
