how do these plugs look? [PICTURE]
Old Jun 15, 2005 | 07:44 PM
Mike92RS's Avatar
How do these plugs look? They're about 2 years old, maybe 20k miles or so on them. I'm trying to figure out why I'm getting alot of soot (and sometimes liquid) in the exhaust.
Old Jun 15, 2005 | 09:12 PM
StealthElephant's Avatar
Car: 87' Iroc
I'm no expert but they look pretty good.
Old Jun 15, 2005 | 10:04 PM
Big AL91's Avatar
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
Look good except the 4 on the right the head connectors do not match the body. Maybe photo angle? Plug wires good? Good Luck!
Old Jun 16, 2005 | 12:42 PM
Mike92RS's Avatar
Do you mean the white stuff on the tip (top of the photo)? I think that's just from the stuff you put in the wire boot before putting it on the plug. The four plugs on the right did come from the left bank, but I probably just rubbed the stuff off of the other ones while spinning them out with my left hand.
Plug wires seemed ok, but I'm putting new Taylor wires on. So what can cause a bunch of soot to come out of the exhaust?
Old Jun 16, 2005 | 05:07 PM
Car: 87' Iroc
Black smoke is running rich. Liquid? Condensation may be coming out of the pipes in the morning.
Old Jun 16, 2005 | 07:35 PM
Mike92RS's Avatar
That's what I dont understand. If the plugs dont look rich, why am I getting so much soot and a strong gas smell? It actually was a really humid day last time I saw liquid, so it could have been condensation.
What does incomplete combustion or a weak ignition system look like?
Old Jun 16, 2005 | 09:22 PM
Big AL91's Avatar
Car: '91 Camaro
Transmission: Auto.
Looking at the plugs and reading your fault topic, it appears problem at Idle or startup and clears or burns off under power. A suggestion appearing odd, change fuel filter(in line). Follow up on cold start procedures if necessary. Others may offer
additional suggestions. Good Luck!
Old Jun 16, 2005 | 09:45 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Those plugs look like they've seen there last days to me
Old Jun 16, 2005 | 10:26 PM
Mike92RS's Avatar
Could you please elaborate? What looks bad about them? They still have the proper gap, dont look fouled, no chips. I'm not being sarcastic or anything, I'm really trying to figure out what's going on.
Old Jun 16, 2005 | 10:37 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Look at the elctrods. They are pretty rounded out and they should be square. Now after some usage they will become rounded out a little but those look like there pretty old and quit a bit rounded
Old Jun 17, 2005 | 12:37 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
2nd from the right seems awful dark compared to the rest.
Old Jun 19, 2005 | 06:28 PM
VILeninDM's Avatar
we did a carb swap on friends 73 vette last summer. The car was running relatively bad. It was popping and black stuff was coming out the tail pipes.
We changed the carb figuring it was at the end of its lifetime whether or not that was the problem. It ran a little better but soot was still there.
We also noticed that smoke from right tailpipe was much darker than from the left one. Later on he took it to a real mechanic and they found that intake seal was bad under the right head and it was leaking coolant into the cylinders on that side. The car also had slight gas smell apparently because we didn't adjust the carb right.
You could try pressure testing the cooling system just to be safe.
Old Jun 19, 2005 | 07:11 PM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
This is easy...
They
look
two
years
old.
You can't read two year old plugs. It's like sticking your finger up your *** to determine what you ate for dinner on10/10/2002. Doesn't work like that, install new plugs, run it or drive it, whatever you are diagnosing for and then pull those plugs and read them. You are wasting your time fiddling with the two year old turds.
Old Jun 19, 2005 | 09:01 PM
VILeninDM's Avatar
bomber has a good point
... so what about last nights dinner?
Old Jun 20, 2005 | 03:02 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Know what's bad? I can remember what I had for dinner 10/10/02...man, I've got issues.
Old Jun 20, 2005 | 10:41 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by Black Bomber
... It's like sticking your finger up your *** to determine what you ate for dinner three years ago. ...
Fixed it for ya thief! Though his point is correct.
Old Jun 21, 2005 | 07:06 PM
Mike92RS's Avatar
ok, interesting analogy
I just did all the standard tune up stuff (including plugs obviously). How far should I go before I check the new ones? I can get to #1 from the top so I can easily pull that one to get a general idea.
Glowsock
Jul 24, 2025 03:15 PM
evilstuie
Feb 28, 2016 03:33 PM
chubsworth
Aug 26, 2015 02:34 AM
Bert87
Aug 23, 2015 03:50 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
