My Introduction(and my Problem)
Hi. My name is Justin and im 16 years old. I have a 1987 Camaro Sport Coupe(base model) with a 305 V-8. This is not a TPI engine, BTW. The engine has been rebuilt, and only has 77,000 miles on it. It is white right now, but by next fall it will be midnight blue. Heres my problem:
When i crank up the car, you have to keep revving it up to get it to stay on. It drives fine, as my uncle has drove it from Raleigh, NC to Nashville, TN and back. But anytime you take your foot off the gas, it idles right off. Some people have told me it is a bad vaccum hose, a bad carburetor, and just a bad engine. The problem with the last two is the engine was rebuilt about 5 years ago, and the meter only reads 77,000 miles. Its been tuned up and the timing set. What do you think is the problem, and how much to fix it, part wise. Thanks.
Justin
Justin
Car: 86' Z28
Engine: 355
You might want to try adjusting your idle screw on the carb. If you look at the linkage on the drivers side, there will be a screw lying horizontal on the linkage that stops it from going back to far, thus setting you idle. If you screw it in some, the carb will stay open a little but more and it will idle. IF its a vacuum line, you pretty much just gotta find the leak. Theres not too many vaccum hoses, so i would just go ahead and replace them all. Vacuum hose is cheap, and it's a nice start to getting acquainted with your engine. Good luck, and welcome to the board
Eric
My 1986 Z2814.59@95.6
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles! no times yet, just got it to start.
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Moderator at: www.generation-3.com
Eric
Thanks. I will go look at it later today. Since im just learning about engines and such, what do you need to change the vaccum hoses? Any special tools or advice you could pass me?
MK,
Welcome Aboard!
I could be mistaken, but unless you have replaced the fuel system when the engine was rebuilt, the stock '87 Camaro SC should have a TBI system, not a carburetor. Or was that 1988? This would change the situation a bit. Can you confirm what you have?
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
Welcome Aboard!
Later,
Vader
Transmission: 4L80E/4L80E
Vader,
In '87, you either got a carbed LG4 or TPI LB9 if 305. LO3 TBI was '88.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 86' Z28
Engine: 355
Man vader, your slipping... thats the second time i've seen you get corrected this week. whats wrong?
Anyway, like the other guy said, you vacuum hoses are pretty easy, just slide the old ones off, and put the new ones on.
Heres a pic of the idle adjust screw in case you couldn't find it before:
and heres a pic of the kind of hoses your looking for and some of there general locations. There pretty easy to spot once you know what your looking for:
Hope this helps you out
Eric
EDIT: MAN!! i thought i sized those pics down! sorry about that. If you have 56K, well... I'm REALLY sorry....
[This message has been edited by zupmanZ28 (edited September 08, 2001).]
Eric
Thanks guys...Those pictures and information has helped a ton. I hope to get to my grandmothers soon, where the car is sitting in the garage, and take a look at it.
Vader: The other guy was correct...In 87 you had the option of a carbed motor or a TPI.
Another question: Anybody know where i can find specs on the engine i have? I know its a 305 V8, stock, but rebuilt.
Car: 86' Z28
Engine: 355
https://www.thirdgen.org/newdesign/tech/techdb.shtml
That should tell you a great deal about your engine, along with the car in general.
Eric
Eric
