How to find a vacuum leak
Old Sep 9, 2001 | 08:17 AM
JoeIROC's Avatar
I have had some driveability problems lately. Someone told me "oh you must have a vacuum leak"...
Whats the best way to chek this. I DO have a hand-vacuum pump with gauge. Honestly, I don't really know how to utilize it to its fullest capacity.
I have tried hooking it up to various parts of the vaccum lines. Every time I try to draw a vacuum, it wont hold steady (the vaccum is lost). I just dont know if thats normal.
Please explain how I am *supposed* to be using this tool.
Joe
86 IROC TPI 305
700-R4 with Trans-go shift kit
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
Gutted MAF
Old Sep 9, 2001 | 11:46 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
a vacuum gauge will not find a leak. It is for testing devices that use engine vacuum.
Get a can of B12 chemtool and spray it around the carb and intake with the motor running. When the engine changes rpm as the spray hits' it, you can identify the general area.
Old Sep 9, 2001 | 04:01 PM
JoeIROC's Avatar
Will ignition fluid (spray can) work as well?
86 IROC TPI 305
K&N Air filters
Dyno-Max cat-back
Gutted MAF
Old Sep 9, 2001 | 04:03 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
starting fluid? ether? Yep.. it will be ok.. just a little more expensive.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
