Temp sensor in pass. side head...
Old Jun 22, 2005 | 12:23 AM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Axle/Gears: Dana S60 4:10
The temp. sensor thats in the pass. side head has a wire that comes from what wire loom? As many times as I've had this thing apart, I can't find the wire. I've gotten under the car and just about stood on my head looking for it. Any help. Thanks.
kwik88
Old Jun 22, 2005 | 12:39 AM
Kwik88's Avatar
Car: 1988 IROC
Engine: 383 SP
Actually it's the fan sensor, not the temp sensor.
Old Jun 22, 2005 | 07:38 AM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I just found mine it was comeing from the driver side by the washer moter . Darkgreen whith prong to go over sensor . My temp sensor was on the drive side head that other one put me on the wrong track for a long time .
Old Jun 22, 2005 | 12:06 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
On my '88 the connector for the Heavy Duty Fan Switch on the passenger side head (Gray wire) runs in the same wire loom (along the passenger valve cover on intake side) as the Injectors, Knock Sensor, TPS, CTS, CSS, IAC, A/C, A.I.R. Solenoids, and Starter. It has the same type of connector as the Knock Sensor.
The green wire on the drivers side is connected to the Engine Temperature Gauge Sending unit.
Bert87
Aug 23, 2015 03:50 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
timonator
Aug 11, 2015 09:56 PM
