How far can you bore a 350???
Old Jun 24, 2005 | 07:36 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
I'm no machine expert and this question really stems out of my own curosity. Firend next door has a Monte Carlo he bought about awhile back whithout (dumb, but he did it) it running, guy claimed it ran nut he took off the intake manifold to sell. We get the car running and there is a pretty bad bottom end knock. We removed the engine and started to tear it down, first thing we found was bronze colored metal pieces in the bottom of the oil pan and stuck to the oil pump pickup screen. We took the rod caps off and found that the bearing were toast. The pistons were also .90 oversized. How much farther can this block be machined or would it just be better for him to find another block?
BTW: Mortec says this is a early 70's 350.
Old Jun 24, 2005 | 07:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd find another block. Most 350 blocks are safe at .060 over. Pushing it to .090 will probably have thin cylinder walls. Early 4" bore blocks are still everywhere. Find a good 010 casting and start fresh.
Old Jun 24, 2005 | 11:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You sure you didn't mistake an 090 for an 060? Regardless, follow the above advice,
Old Jun 25, 2005 | 12:17 AM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
You can bore them to the water jackets....then pound in new sleeves
Old Jun 25, 2005 | 03:40 AM
ede's Avatar
ede
with a .90 overbore you'd have each hole overlapping the next one by about a half inch, except the end ones, they'd be out in the air at each end of the block.
Old Jun 25, 2005 | 07:06 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
.060 if it's been sonic checked.
Old Jun 25, 2005 | 03:38 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Hehe, yea, your right, it's a 60 over bore. apparantly I have dexlexia.
Anyway, cant go over 60 anyway can you? The internals looked pretty new so what would cause the bearings to go out that fast? I was thinking lack of oil.
Old Jun 25, 2005 | 03:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What ede is trying to get at is that even if it was bored "90 over", it would be .090", not .9"
If it needs further boring at .060, find another block. Even if the cylinder walls were thick enough to take more, pistons would start getting hard to find. If the cylinder walls are still in good shape, you could hone it, ring it, and not have to worry about it for years.
Old Jun 25, 2005 | 06:34 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Wouldn't rebore beyond that. Take a close look at the cylinders for hone crosshatch markings, sort of a pattern of scratches. If still there and all uniform looking with no worn spots, the block might be a good one to rebuild. Need a crank kit and a couple new rods, really clean the entire block and new cam bearings. If it needs rebore at this point, might be way ahead to get a crate engine from GM, roughly the same money for a brand new engine.
Hotrodboba400
Dec 10, 2019 07:07 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
