Goofy Oil Pressure Gauge
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
My oil pressure gauge started acting weird today, I could be going down the highway at 60mph(or any speed for that matter) the gauge starts to jump around then will stick in a position, then jump around some more and then stop. Any ideas as tot he problem? Oil Pressure sending unit?
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Change your oil recently?
This is generally a sign of a failed sending unit. The factory senders were notorious for this type of behavior.
BTW, where is the Oil pressure sending unit located at in the block?
Could this also be why the car takes about 3-4 seconds to fire up?
Car: 1991 Chevy Camaro
Engine: 305 TBI
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by Apeiron
Maybe, if your fuel pump relay is also dead.
Engine: 383 Carb
Transmission: 4L60
Do you hear the fuel pump running for 2 seconds when you first turn the key on, before you start the engine?
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
i had the same problem with the oil guage. There is a OIL SENDING UNIT and then there is a OIL PRESSURE SWITCH i changed the pressure switch which is located behind the distributor and this fixed the guage from jumping around crazy. ANd this also fixed a oil leak i had
Hope this helps any
Hope this helps any
ambainb
Apr 25, 2016 09:21 PM
