O2 bung PLUGS?
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
O2 bung PLUGS?
I need a threaded plug for the oxygen sensor bung- where can I get one? I was using a 3/8" pipe plug but it fell out (it's not wide enough). I don't happen to have my O2 sensor laying around either, otherwise this wouldn't be a problem. Exhaust leak is annoying and trashy.
thanks.
thanks.
Car: 1992 Firebird
Engine: forged 357
Originally posted by Apeiron
Stick a spark plug in it.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Good idea!
As long as the hole is filled....I mean hell you're carbureted, not like it matters
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If that sounds a little too crude for you, plugs are available. K&N P/N 85-21686, or Dynomax 35299.
Used spark plugs are cheaper though.
Car: check
Engine: check
Transmission: check
Even a new spark plug is cheaper then the plugs sold as O2 sensor plugs.
Needs to be an 18mm, unlike our cars which use a 14mm spark plug.
An Autolite 386 spark plug works.
RBob.
Needs to be an 18mm, unlike our cars which use a 14mm spark plug.An Autolite 386 spark plug works.
RBob.
wigmobile
Feb 26, 2025 02:56 PM
89 formula TPI
Sep 7, 2015 11:06 AM
