OIL??
Old Sep 15, 2001 | 02:51 AM
jmp1999's Avatar
OIL??
Ok kind of a dumb question, but what kind of oil are all of you guys using?
Like penzoil
mobil 1
castrol
valvoline
whats the best in your opinion
I was brainwashed as a young lad to use reg.penzoil but i know there has got to be better on the market now.
Old Sep 15, 2001 | 03:09 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i use castrol 10w-30
84 z28
[URL=http://www.geocities.com/yuelb/Car.jpg]html
Old Sep 15, 2001 | 03:28 AM
rezinn's Avatar
I used to use havoline 10-30, but I've changed to mobil 1 15-50.
Old Sep 15, 2001 | 04:23 AM
EvilCartman's Avatar
Car: '82 Z28
<font face="Verdana, Arial" size="2">Originally posted by yuel:
</font>
ditto
'82 Z28
LG4 305 .030 over, performer intake, holley street avenger 670, xe 256 cam, tes headers, 3 inch single exhaust, spintech muffler, 14 x 3 inch drop base k&n.
Old Sep 15, 2001 | 05:32 AM
ede's Avatar
ede
what differance does it make waht oil i use? if you're going to run a oil based on a popularity contest i'd be looking else where for my info, like national sales figures, or even what oil sponsers the racing i like. i believe it's better to have oil and filter that are changed on a regular basis than a big name or high dollar oil that isn't.
i use pennzoil and mobil 1 for all my cars. trucks, and equipment.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 15, 2001 | 08:55 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Mobil 1 10w-30, and always get over 60 psi pressure! (yep, I already replaced the oil pressure sender...)
-Erik
1987 Camaro IROC-Z28
355 TPI / A4 3.23:1p
"Slower than a wal-mart cashier"
1979 Malibu
307 Q4 / A4 2.??:1
"Did you hit the gas yet?"
Old Sep 15, 2001 | 09:31 AM
u r sofa king we tah did's Avatar
i use mobil 1 and nothing else period because of performance it has given me in the past. pennzoil is one of the worst oils when it comes to sludge build up, but changing regularly combats that. mobil 1 will not sludge up period. no matter how long your intervals are between oil changes.
Old Sep 15, 2001 | 09:49 AM
FormulaKid's Avatar
Car: 1989 Firebird Formula
I've been using mobil 1 15W-50 for a while and am very happy with it.
Old Sep 15, 2001 | 01:07 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I went from valvoline durablend, to valvoline tri-synthetic, to mobil 1 tri-synthetic, and have been very happy with all of them. I think it makes the car run better, of maybe I'm just thinking it.
late model 91 rs
fully loaded t-tops, red leather
paint- gm red and yellow blend (light red)
custom painted 16" Camaro rims
305 tbi 14"x3" O.E, hypertech chip, accel super stock plug wires
Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: a lot of "family" cars, pickups, New v-6 stang, totally killed '86 SC Camaro, 91 z 28 with 305
next month: rest of ultimate tbi
Old Sep 15, 2001 | 02:24 PM
82camaro's Avatar
Car: 82 camaro SC
Ede got it right. Use a good brand and change it and a good quality filter every 3000 miles. I use wal-mart super-tech synthetic(quaker state) blend and baldwin filters for a very long time without any problems. A good filter makes a huge difference. The farmers around here can show you the difference in cheap filters when they run a deep well 24x7 for weeks at a time. Poor filters(fram for example) plug quickly allowing bad oil to return to the pan, sometimes the filter even breaks down and the filter element ends up in the pan.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 15, 2001 | 02:30 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Over 175,000 miles with Mobil 1 5/30. Hardly burns any oil, no cloud of blue when I start up. You can pay a little more now, or pay a lot more later.
No regular brand of oil has ever stood up as well in my 30 years of driving.
Old Sep 15, 2001 | 06:30 PM
ede's Avatar
ede
read Mr Vaders reply to this thread, it contains a little more than an opinion or limited experience with his cars or his neighbors.
https://www.thirdgen.org/messgboard/...ML/012364.html
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
