U-Joint failure, engine damage?
Old Jul 3, 2005 | 01:23 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I had a U-joint crack in half. It started as a bad vibration under load, then vibrated all the time then as I was limping home bam! It did vibrate bad enough to loosen all the header bolts. Now the headers are fixed I'm geting a tick under load from the engine. It wont tick reving the engine or tick long enough to isolate. It sounds like a lifter noise so it proably is but.
Could the vibration have caused internal damage?
Oh and DS loops do work even on daily drivers.
Old Jul 3, 2005 | 01:42 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't see how it could cause internal engine problems... did you check your header collector bolts? You could have an exhaust leak there too. If the header bolts loosened off from the vibration, the collector bolts possibly could have too.
Old Jul 3, 2005 | 07:53 AM
ede's Avatar
ede
doesn't seem unreasonable that it could beat on a bearing if it was bad enough to loosen the header bolts, especially if you're running a manual trans. i think i'd look at everything else first and try to eliminate that as the source before i jumped into the engine.
Old Jul 3, 2005 | 10:38 PM
Air_Adam's Avatar
Looks to me like he's got an auto.
Old Jul 4, 2005 | 06:22 AM
ede's Avatar
ede
so? what's your point? does it matter? you can't really tell what he has after you click reply.
Old Jul 5, 2005 | 10:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you 100% sure the tick isn't a header leak?
Old Jul 5, 2005 | 11:06 AM
sellmanb's Avatar
Car: '86 Berlinetta
like Five7's saying (I think?) ... if it was bad enough to back the header bolts out a little, then it probably blew the header gasket while the bolts were loosened.
Try taking them out and inspecting them.
Old Jul 5, 2005 | 12:31 PM
five7kid's Avatar
You think correctly.
Old Jul 5, 2005 | 01:27 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It is actually a manual transmission.
I put a few more miles on it then drained the oil, looked clean, cut the filter open dident find any metal. Did find ASH deposits in the bottem of the filter which dident make me too happy but at least it was traped in the filter.
I took the passenger side header gasket off (Percey) found a few spots where the gasket was cracked, slaped a cheap set of Mr gaskets on and the noise is no more. I should have checked the header gaskets better but these aluminum gaskets are supposed to be nearly indestructible and I ran my stethoscope all around them dident hear any leaks.
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
