Low Speed Vibration
Old Sep 14, 2001 | 10:45 PM
88 IROC BOB's Avatar
Low Speed Vibration
I just recently took out my Vig convertor and replaced it with my stock one. My problem is that now the idle seems rough and when I get on it out of the hole there seems to be a vibration during the first couple hundred rpm's.
It didn't do this with the Vig in and I'm sure it wasn't doing this before when I had my stock one.
Anyone have any idea?
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Sep 15, 2001 | 09:59 PM
Does this sound like the convertor staying locked up. It idles like crap now and when I tapped the brakes while driving at highway speed it didn't seem to unlock.
How else can I determine if this is the problem?
Bob
Old Sep 15, 2001 | 10:03 PM
Vader's Avatar
Bob,
You could try to disconnect the TCC and drive it again. If the TCC is not unlocked, you won't be able to keep the engine running while standing still in gear.
Later,
Vader
Justice and Freedom will Prevail
Old Sep 17, 2001 | 12:48 PM
It will run while in gear, it does idle low and rough though. Could be a miss at low rpm but what would cause this just by changing convertors?
Bob
Old Sep 17, 2001 | 01:31 PM
82camaro's Avatar
Car: 82 camaro SC
A tighter stock converter will lower the idle speed. It will slip less and lug the engine more that a loose converter and slower speeds.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 17, 2001 | 07:36 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Once, along time ago, I swapped the tranny in my 68 Camaro Convertible. On the way back to Florida I got a terrible vibration, felt like the engine was going. Turns out I had about a 1/4" gap were the tranny bolts to the engine on one side. I sweated for over 700 miles thinking the bottom end was ready to let go when It was my fault for not properly mating the tranny to the engine.
Just one possibility. I also had a vane collapse in my 91 Z28's torque converter. Gave me a vibration at 70 mph and again at 110mph. Doubt that's your problem though.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Sep 18, 2001 | 10:50 AM
Problem solved. Are you ready for this--a burnt plug wire. That's right I was basically running on 7 cylinders. That's a good way to make it idle like crap and run like a slug.
Thanks for all your suggestions.
Bob
Old Sep 18, 2001 | 11:24 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
LOL - i hate when ya think your car is falling apart and you're ready for the engine to blow only to find out its something that simple. I thought my engine was knocking one time and i thought 'well, crap - its finally given up'. Later, I found out that my A/C compressor bracket was a little loose and was rattling...Another time, I thought my rear end was going out because the car would lurch off the line and it felt like someone was dropping a bowling ball in the trunk. Then I found out my motor mounts were shot and allowing the engine to jump up...
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Americanmouse
Sep 7, 2015 12:10 PM
Thornburg
Aug 27, 2015 08:28 PM
perZ
Aug 15, 2015 01:17 PM
novaderrik
Aug 10, 2015 12:44 PM
